[Plugin] LordOfTheToolbars - v2.7b - 07 Apr 24
@fredo6 said:
@aismebel said:
Hi. I'm ashamed that I can't figure out how it works. Maybe someone will record a training video?)))
There are videos in the first post of this thread. There are others on YouTube.
Hi Fredo. Perhaps you misunderstood me. I wanted to see a video in which, with the help of a script from the author of panixida, it will be possible to use the command menu. The menu is a very convenient tool, its absence does not allow me to switch to SU2023.
Hello,
I have installed LordOfTheToolBars on sketchup 2023, but there is no access to any menus tools. Only icons. It means that i can't creat icons, anything.
The most interresting thing about your plugin.
What can I do to fixe or modify to fixe that link problem.
Thanks for your help. -
@laurent002 said:
Hello,
Thanks for your help.Yes. Menu disappeared due to change of UI framework for Su2023 on Windows (on Mac this is still available). No workaround possible, unless Trimble provides new API methods.
@laurent002 said:
Hello,
Thanks for your help.Not exactly the same, but you can achieve similar result with this workaround.
http://sketchucation.com/forums/viewtopic.php?f=323&t=73776&view=unread#p687744
Thanks for the suggestion, I will give a try
I seem to have lost the Quick Command finder. I'm using Sketchup 2021 pro, and have the latest LibFredo and LOTT. I've tried reinstalling LOTT and have Sketchup installed as admin.
Is there any way to reset the position of where the quick command finder dialog pops up - or have I broken something?
Thanks v much
T -
I seem to have lost my Quick Command Finder pop up. I'm all up to date, Sketchup installed as admin, and have reinstalled LOTT.
Is there a way to reset where the popup pops up - or have I missed or broken something? I'm on 2021 Pro.
Thanks! -
Is there a way to reset where the popup pops up - or have I missed or broken something? I'm on 2021 Pro.Do you have several monitors?
I'm on a laptop with an extra screen. I disconnected the second screen when I was trying to retrieve the popup. No luck though.
Could you do the following
- Open the Ruby Console
- Launch the LOTT Find dialog
- Copy paste the following command in the Ruby console and press Enter
Traductor::ChromiumWdlg.check_instance_displayed("LOTT_MiniFindDialog", true).set_position(0, 0)
The Find dialog should go to the position top left corner of your screen.
That solved it. Thanks so much.
Take care
T -
Hi Fredo. Please tell me, is the operation of "menu" in SketchUp 2023 expected to be restored in the future? Is there any news?
It fully depends on the Sketchup developers. I filed the requests some time ago.
But, frankly, no idea.... -
Your plugin is amazing, I can't imagine further use of SU without it. Ot perfectly optimizes the workspace, "menu" is an integral part of it. Maybe we can help? I suggest, just like you, to make a request to the developers of SU.
Thanks again for all your great plugins!
I have a question on LordOfTheToolbars. 2.4a
I am using Mac (mac OS Montrey).
I would like to use skp2023 but the icon hover does not work.
I was able to use skp2022 with no problem. -
I am using V-ray, but I cannot customize the icons.
V-ray does not appear in the master toolbar manager...
I would like to ask if this can be improved in the settings.
Thank you in advance for your confirmation. -
Hey, I'm having an issue installing in SU2021. It says "Could not unzip archive".
Don't know why nor what to do.
How are you trying to install it?
What operating system? Please complete your forum profile.
Thanks for the reply.
Downloaded from here https://sketchucation.com/plugin/2430-lordofthetoolbars
Installing from:
a. DropZone, no apparent error.
b. Install Menu, "Could not unzip archive".
c.Extension Manager, just "Failed"
OS, Win10
Download and install the Sketchucation ExtensionStore tool. Then use it to install the extension.
Which version of SketchUp? Did you install SketchUp correctly? That requires right clicking on the downloaded installer and selecting Run as administrator.
Hello how are you.
I wanted to report that when I open sketchup 2023 it never remembers where the custom bars were anchored.
And I have to be locating them every time I open sketchup.
Another thing that I notice is that the tools created from the menu no longer work and I know that they are installed.
I use Sketchup 2023 and LordOfTheToolbars v2.4a
In what you can help me, I appreciate it.
Greetings.
