Shape Bender producing 2D results
• Page 1 of 1
Shape Bender producing 2D resultsGood day. This is my first time using Shape Bender. I have done all that I can but cannot seem to surpass this issue. Whenever Shape Blender is applied there are no errors...just flat, 2D results.
Re: Shape Bender producing 2D resultsPost your skp in v 2017!
Re: Shape Bender producing 2D resultsElse Shape Bender works fine like it must to do with a vertical flat group!
![]() For avoid the big deformation of one part of the cross result Take the same length of the horizontal cross'length than the length's Arc! ![]() That is not the case here! ![]()
Re: Shape Bender producing 2D resultsMaybe True Bend by Thomthom will be more suitable ?
Re: Shape Bender producing 2D resultsMy apologies! Here is the true before ans after:
Re: Shape Bender producing 2D resultsYou need to attach your model for us to give a full answer, but it looks like it is doing what you have told it to do.
23:9
Re: Shape Bender producing 2D resultsHere in the SKP in 2017.
I was following a tutorial and modified the form a bit to suit my own interests. In the tutorial, the individual is able to achieve a more 3-dimensional form, if you will Re: Shape Bender producing 2D resultsIt's what I thought from your photo, the arc is on the wrong plan.
23:9
Re: Shape Bender producing 2D resultsAs said in my previous post you will have deformations!
![]() (needing or not, depending of the result really wanted! ![]() Arc's length is 24,15 m Line's length is 22, 94 m So for a perfect result arc must be reduced! ![]() Last edited by pilou on Tue Jun 14, 2022 6:21 pm, edited 1 time in total.
Re: Shape Bender producing 2D resultsAs True Bend works only Object by the middle maybe you can use this little trick!
![]() Open the component and add a little line! ![]()
• Page 1 of 1
Who is online
Users browsing this forum: No registered users and 0 guests
