Window Builder updated (v 1.1.0)
Postby Didier Bur » Fri Jul 26, 2019 10:04 am
Hi all,
New release on the EW site today: http://extensions.sketchup.com/en/node/6841
What's new in v 1.1.0:
  • Ability to save and load presets
  • Ability to preset custom layers for 7 parts of the window
  • Bar dialog fixed, (typo in the EN-US language file)
  • Fixed bug: loosing some values when configuring accessories (bar, shutter, etc)
  • Fixed bug: help button ineffective in the window by face dialog
  • Dialogs are now modal on PC and on Mac
  • Cosmetic graphics changes (homogeneous button sizes)
  • Replaced "Component name" with "Custom name" in the dialog
  • Donate button added
  • PDF Help file updated
16
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
User avatar
Didier Bur
Re: Window Builder updated (v 1.1.0)
Postby nguyentuyen1986 » Tue Aug 06, 2019 5:41 pm
Hopefully this plugin becomes a paid version with many added doors & windows.
nguyentuyen1986
Postby gameongrant » Wed Aug 07, 2019 12:20 am
Great plugin! Agreed, multiple configurations would be great. Also the ability to use custom sections would be brilliant. Keep up the great work Didier
gameongrant
Postby Didier Bur » Fri Aug 09, 2019 5:34 am
Hi all,
The next release I'm working on will have the following changes:
3 window types added: single opening, side-hung, australian
New glazing type added: jalousie
Materials are now saved in presets
Replaced "Sashes" with "Window leafs" in the dialog
Fixed bug: loosing "snap to" and "cuts opening" values when using the eyedropper
Fixed bug: wrong screen box drawing if screen opening percentage was zero.
Fixed bug: wrong cover profile drawing when "Both" option was selected.
New (experimental) interactive tool to open/close casements
7
Didier Bur
User avatar
Didier Bur
Postby Rudhamstile » Tue Nov 12, 2019 1:44 pm
Failed to install this extension in SU 2018.
Have tried a new SU Repair install admin rights etc.
Rudhamstile
Postby Dave R » Tue Nov 12, 2019 1:51 pm
What do you mean exactly by "failed to install"? How did you attempt to install it? What is telling you that the installation failed?
User avatar
Global Moderator
Postby yovanygonzalez » Sun Jan 12, 2020 4:38 am
I have a problem. I am trying to use the Windows Builder plug-in and, for some reason, when I tried to open the hole, the windows did not cross the wall, staying on the face. Any ideas?
Thanks in advances
yovanygonzalez
Postby Didier Bur » Tue Jan 14, 2020 9:08 am
Hi Yovanygonzalez,
Could you please post a SKP including such a "stick-to-face" window ?
Thx
Didier Bur
User avatar
Didier Bur
May not Create Window in MacOS SU-2021-pro
Postby mark_in_seattle » Sun May 02, 2021 10:34 am
Looks like a very good and useful plugin. Unfortunately, myself and a few other MacOS users with SU-2021-pro are able to install the extension and use the settings window..etc, however clicking CREATE & PLACE does nothing, creates nothing on any layer..... bummer.
Anyone running SU-any-version under a MacOS able to create windows with this extension.
-- thank-you
User avatar
mark_in_seattle
Postby allanpepito » Tue Sep 21, 2021 10:54 am
I'm first timer. I love the SU and its plugins including Dib's window builder. I have a bit of an issue and hope someone can point out what I've done wrong here. I tried to use the window builder latest version 1.1.0 and noticed when I pressed the wall puncher the hole was created but not exactly on the spot where the window is located. The hole is horizontally fine but vertically lower by ~250mm. Note the wall had guide lines on it. If there are no guides on the wall it works perfectly. The problem only appears when guides are present in the wall. I need the guides for placing the window in the correct location.
Tried various tricks but failed to figure out what exactly is happening. Hope you can guide me as I'm beginner. Thanks in advance.
allanpepito
Postby Dave R » Tue Sep 21, 2021 3:51 pm
Share your .skp file with us so we can see what you have set up.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: DoMiniC81, francofari9, howardhong, Mahmoudjibreel, sb96 and 19 guests
