[Plugin Library] LibFredo6 - v14.4a - 10 May 24
Hi Fredo!
What a wonderful set of plugins you have done! I am grateful to you, your work is sparing me loads of time!!!I'd have a question: is there any chance your tool "area report by material" could take into account ALSO the faces which are painted from the outside of a group/component? Since I work a lot with DCs this would be a greatly useful add-on..
Thanks in advance!
This is a good idea, and I think this is manageable.
NEW RELEASE: LibFredo6 v9.5d - 03 Feb 20
LibFredo6 9.5d fixes a major regression bug affecting Curvizard, preventing the generation as Sketchup curves for some tools. It is strongly advised to upgrade
NEW RELEASE: LibFredo6 v9.5e - 05 Feb 20
LibFredo6 9.5e is a minor release
- necessary for FredoTools::ReportLabelArea to count face area by material when material is applied to groups or components instead of faces
- For the opening of certain files on Mac, due to changes made in SU2019.3 and SU2020.
This is now available in FredoTools::ReportLabelArea v3.2a, with
For some reason I can't install libfredo 9.5.e on SU2020 (win10 64 bit)
The Lib installs fine for me [same OS etc] and it is fully signed etc...
Manual extract to plugins folder solved the issue.
NEW RELEASE: LibFredo6 v9.5g - 09 Feb 20
LibFredo6 9.5g is a minor release necessary for Animator and FredoTools::MoveAlong. It corrects a problem when moving objects.
NEW RELEASE: LibFredo6 v9.5f - 08 Feb 20
LibFredo6 9.5f is a minor release necessary for VisuHole to capture stencil from container where axes are not oriented with Z being the normal to the thin plate.
Thank you so much for creating these tools, extremely valuable to my work flow.
You are
Awesome & Amazing ! -
can you use this plug in with sketch up for web? like the free version?
when I go to Window the options outlined are not there.ty.
No. As I told you elsewhere yesterday, the web versions of SketchUp have no implementation for using extensions.
NEW RELEASE: LibFredo6 v9.5j - 25 Feb 20
LibFredo6 9.5j is a minor release for fixing a bug in some rare situations where the model has no attribute at all.
NEW RELEASE: LibFredo6 v9.5h - 13 Feb 20
LibFredo6 9.5h is a minor release necessary for Animator. It corrects a problem when Easing functions.
Hi Fredo,
Do you know how to fix the problem shown as below,
[img]file:///C:/Users/SUN/Desktop/%E9%98%BF%E9%87%8C%E6%97%BA%E6%97%BA%E5%9B%BE%E7%89%8720200303012702.jpg[/img]
I tried the su2019 and 2020, But the SU still failed to load the Fredo6
Please help
Thank you
The image is missing you cannot link to a file that is on your own PC !
Try copy/paste ? -
Try copy/paste ?Sorry,this is my first time to use this.
载入文件 C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe 时出错
Failed to read RBE/RBS file.
载入文件 Fredo6_!LibFredo6.rb 时出错
Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:inprocess' C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in
module:LibFredo6_Loader'
C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'thank you
This 'failed to load RBS/RBE' seems to be a problem related to the installation of Sketchup.
Could you reinstall it, with 'run as administrator'.
Yes, I did. But the error still exist.
I didn’t find any available solutions to deal with it.
