[Plugin Library] LibFredo6 - v14.3d - 21 Apr 24
Could you post or PM me the model.
Because of this error, the process of protection does not start and thus is not active for this model.
Hi Fredo,
I just updated libfredo and it seems to have caused an issue with Curvizard.
Any curve and any action creates stange edges between points.
@box said:
Hi Fredo,
Any curve and any action creates stange edges between points.Many thanks for signaling the problem.
Definitely a major bug, which I fixed in LibFredo6 v9.5c, just published.
NEW RELEASE: LibFredo6 v9.5c - 10 Jan 20
LibFredo6 9.5c fixes a major regression bug affecting Curvizard. It is strongly advised to upgrade
Thanks Fredo for being so proactive and responding so quickly on all your plugins. On my phone at the moment so will confirm as soon as I'm able.
Thanks again Fredo.
Hi Fredo
Many thanks for looking at the issues with my file and FredoGuides. I sent you a separate PM with a WeTransfer link. Hopeful the file can shed some light and provide the necessary feedback. -
Hi Fredo!
What a wonderful set of plugins you have done! I am grateful to you, your work is sparing me loads of time!!!I'd have a question: is there any chance your tool "area report by material" could take into account ALSO the faces which are painted from the outside of a group/component? Since I work a lot with DCs this would be a greatly useful add-on..
Thanks in advance!
This is a good idea, and I think this is manageable.
NEW RELEASE: LibFredo6 v9.5d - 03 Feb 20
LibFredo6 9.5d fixes a major regression bug affecting Curvizard, preventing the generation as Sketchup curves for some tools. It is strongly advised to upgrade
NEW RELEASE: LibFredo6 v9.5e - 05 Feb 20
LibFredo6 9.5e is a minor release
- necessary for FredoTools::ReportLabelArea to count face area by material when material is applied to groups or components instead of faces
- For the opening of certain files on Mac, due to changes made in SU2019.3 and SU2020.
This is now available in FredoTools::ReportLabelArea v3.2a, with
For some reason I can't install libfredo 9.5.e on SU2020 (win10 64 bit)
The Lib installs fine for me [same OS etc] and it is fully signed etc...
Manual extract to plugins folder solved the issue.
NEW RELEASE: LibFredo6 v9.5g - 09 Feb 20
LibFredo6 9.5g is a minor release necessary for Animator and FredoTools::MoveAlong. It corrects a problem when moving objects.
NEW RELEASE: LibFredo6 v9.5f - 08 Feb 20
LibFredo6 9.5f is a minor release necessary for VisuHole to capture stencil from container where axes are not oriented with Z being the normal to the thin plate.
Thank you so much for creating these tools, extremely valuable to my work flow.
You are
Awesome & Amazing ! -
can you use this plug in with sketch up for web? like the free version?
when I go to Window the options outlined are not there.ty.
No. As I told you elsewhere yesterday, the web versions of SketchUp have no implementation for using extensions.
