error with generating report
Found a bug in SketchUp? Report it here
Postby pibuz » Wed Nov 28, 2018 11:58 am
Hi guys, i just installed SU2018, but somehow the report utility fails to load..
The ruby console throws this message
"Error: #<NoMethodError: undefined method `to_json' for #<Hash:0x0002a849deeb78>>
c:/users/filip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/generatereport.rbe:359:in `pull_attribute_tree'
c:/users/filip/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/generatereport.rbe:94:in `block in initialize'
SketchUp:1:in `call'"
Any ideas about how I can fix it?
Thanks in advance!
pibuz
Re: error with generating report
Postby juju » Wed Nov 28, 2018 1:05 pm
pibuz wrote:Hi just installed SU2018
Did you install via right click > run as administrator? If not then do this and do a repair installation. Else just reinstall using this method.
User avatar
juju
Premium Member
Premium Member
Postby pibuz » Wed Nov 28, 2018 1:09 pm
I'll retry immediately, just to make sure...
pibuz
Postby pibuz » Wed Nov 28, 2018 1:20 pm
Nothing.
And now SketchUp freezes, and can't continue.
I'm astonished. The Laptop is completely new, and SketchUp refuses to work. I truly don't know what to do.....
pibuz
Postby juju » Wed Nov 28, 2018 1:29 pm
pibuz wrote:The Laptop is completely new
What are the specifications of the new machine? I assume it is a windows machine? Have you restarted inbetween?
User avatar
juju
Premium Member
Premium Member
Postby pibuz » Wed Nov 28, 2018 1:33 pm
The Machine is very powerful, it absolutely not an hardware problem. Moreover, I'm a very long time SU user, so really BASIC operations like installing and opening the program should be absurdly easy.
And yet, it doesn't work....I don't know why...
I tried uninstalling and reinstalling but this doesn't fix anything.......
pibuz
Postby juju » Wed Nov 28, 2018 1:42 pm
Yeah, I know you're a long time SU user pibuz (with some nice stuff as well), just trying to help.
Maybe try to get SketchUp to make good on their support & maintenance?
Hmmm. How's your internet connection / connectivity? I've had some strange error messages from SU when this is compromised. Whenever the internet connectivity is strong / fine there doesn't seem to be problem error messages. Also when it's off (no internet connected) I don't have error messages, just when connectivity is compromised. This not the case here either?
User avatar
juju
Premium Member
Premium Member
Postby pibuz » Wed Nov 28, 2018 2:31 pm
Connection also is excellent!
When trying to uninstall/re-install the first time I run the program it's ok, the second time it starts freezing......
maybe it's something related to the license check? Maybe a difficult check due to restrictions in outgoing signals of OUR firewall?
pibuz
Postby pibuz » Thu Nov 29, 2018 11:24 pm
...seems like I can't even open a sketchup file now....
I begin to think the issue here is the integrated video card drivers...... I'm running on a UHD graphics 630..... is there something I can do to fix this?
I can't work at all....
pibuz
Postby juju » Fri Nov 30, 2018 7:52 am
Please tell me the laptop has a dedicated GFX solution? You'll need to set preferences making SU / LO run only on dedicated GFX solution.
User avatar
juju
Premium Member
Premium Member
Postby pibuz » Fri Nov 30, 2018 9:02 am
Obviously yes: there's a GTX 1050 with 4GB dedicated.
Yesterday evening I kept on testing the issues: I can install and run SketchUp 2017, but I cannot launch Indigo renderer and enscape. Both freeze...... :?
EDIT: sorry Juju: what's "LO"?
pibuz
Postby juju » Fri Nov 30, 2018 9:08 am
SU = SketchUp
LO = LayOut
User avatar
juju
Premium Member
Premium Member
Postby pibuz » Fri Nov 30, 2018 9:11 am
Thanks! Strangely, layout shows no issues. At all.
pibuz
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Bug Reporting
Who is online
Users browsing this forum: Google Bot and 0 guests
Visit our sponsors:
