[Plugin Library] LibFredo6 - v14.3d - 21 Apr 24
by process of elimination i discovered today that Fredo6 plugins are making my SU 2017 Pro run very very slow at satrtup and when i invoke the toolbards dialog box. I disabled all my plugins to find that sketchup ran fine. i enabled Fredo 6 lpugins again and slowness occurs again. I ahve udpated to latest version of all Fredo 6 plugins but have found the probelm persists.
windows 7 64 bit syste 32GB ram
Video Card Nvidia quadro M1000MEdit: perhaps not, also disabled Vray and find better performance.
You have a performance menu entry showing the time to load for my plugins. I am interested by the result.
Is the slowness only for the startup time, and/or after when you model in Sketchup. Do you observe a lag after you see all toolbars displayed?
NEW RELEASE: LibFredo6 v8.5b - 14 Jul 18
LibFredo6 8.5b is for Animator 2.2b (Full Screen option) and bug fixing
Hello, I'm having trouble installing LibFredo6, the error message appears:
Erro ao carregar o arquivo Fredo6_!LibFredo6.rb
Error: #<ArgumentError: invalid byte sequence in UTF-8>
c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:ingsub' c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in
get_dir_from_ENV'
c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:indir_appdata' c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in
startup'
C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:inprocess' C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in
module:LibFredo6_Loader'
C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in<top (required)>' Erro ao carregar o arquivo Fredo6_JointPushPull.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in
C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in<top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in
require'
C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:inrequire' C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in
module:Fredo6'
C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in<top (required)>' Erro ao carregar o arquivo Fredo6_RoundCorner.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in
require'
C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:inrequire' C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in
module:Fredo6'
C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'It does not open in the window bar, but old versions work.
I use Windows 8 and SketchUp Pro 2017. -
The accented "i" in your [Portuguese ?] Windows user name [
tha**í**s
] is almost certainly causing the issue.
Accented characters broke many scripts, until the newer versions of SketchUp got an updated Ruby installation, with extra tools available to try and circumvent such problems...However, Fredo's tools have for a long time forced file-path encoding etc into UTF-8 format...
So I am surprised that this issue has occurred, let's wait for Fredo's comments... -
NEW RELEASE: LibFredo6 v8.5c - 31 Jul 18
LibFredo6 8.5c fixes issues with non-ascii Windows usernames
NEW RELEASE: LibFredo6 v8.5f - 14 Aug 18
LibFredo6 8.5f increases the timeout for rendering in Vray from Animator. It also fixes other bugs.
SU 8 free. Updating I get this:
Error Loading File Fredo6_!LibFredo6.rb
undefined method `startup' for LibFredo6:ModuleError Loading File Fredo6_FredoScale.rb
no implicit conversion to float from nilError Loading File Fredo6_RoundCorner.rb
no implicit conversion to float from nilaiiii, what's wrong please, please help
regards Helle
regards Helle
Fredo6 is upgrading his extensions, support for some older versions of SU are being deprecated to facilitate compatibility with newer coding. SU8 would definitely be on the list of no longer supported SU versions.
oh, what a shame. I read it as "pre-8" and thought I could use it. Thanks for the fast reply
any chance someone has a copy of the last pre-su8-deprecated version of libfredo? not even sure which version that would be..
I am still using SU8 and have been for many years. Will not upgrade, been everything I need and more. Any way to upload SU8 compatible versions again for use?
NEW RELEASE: LibFredo6 v8.5h - 27 Aug 18
LibFredo6 8.5h reestablishes the compatibility with SU8 and SU2013, which was broken with the previous version
NEW RELEASE: LibFredo6 v8.6a - 06 Sep 18
LibFredo6 8.6a is dedicated to the first public version of FredoCorner
New version of Spanish language file:
NEW RELEASE: LibFredo6 v8.6c - 08 Sep 18
LibFredo6 8.6c fixes a problem of orbiting in FredoCorner.
It also integrates an update to the Spanish translation by Oxer.
NEW RELEASE: LibFredo6 v8.6d - 11 Sep 18
LibFredo6 8.6d includes a full French translation and fixes problems for FredoCorner 1.1c.
NEW RELEASE: LibFredo6 v8.6e - 19 Sep 18
LibFredo6 8.6e includes a Spanish French by Oxerand fixes problems for FredoCorner 1.1d.
NEW RELEASE: LibFredo6 v8.6f - 23 Sep 18
LibFredo6 8.6f fixes problems for FredoCorner 1.1e.
