Render with SU edges
General discussion on Thea Render for SketchUp
Moderator: Frederik
Postby sfto1 » Thu Aug 10, 2017 8:17 pm
Hello All,
I was rendering with Thea in the SU window with SU edges on. Very interesting look. I saved the image, but the edges do not appear in the saved image. Not the effect I was figuring to get.
Am I doing something wrong that I am losing the edges when I save?
User avatar
sfto1
Premium Member
Premium Member
Re: Render with SU edges
Postby TIG » Thu Aug 10, 2017 8:36 pm
Most renderers don't render edges.
Idea: make the render of the faces as normal.
Using the same view make a new scene-tab, and export a second image - Hidden Line, without shadows to get the edges [white background defaults, so it can be made transparent later].
Now using Photoshop, Gimp etc you can 'merge' the two images, overlaying the line works over the rendered images of the faces...
User avatar
Global Moderator
Postby sfto1 » Thu Aug 10, 2017 8:52 pm
Thanks TIG.
I can do that. I was thinking that Thea was saving me those steps. :? I'm just wondering why Thea let's me see that on screen but doesn't export.
User avatar
sfto1
Premium Member
Premium Member
Postby TIG » Thu Aug 10, 2017 9:45 pm
I don't know enough about Thea to advise you... can you post in their own forums ?
User avatar
Global Moderator
Postby sfto1 » Thu Aug 10, 2017 9:58 pm
Yup. That's next on my list.
User avatar
sfto1
Premium Member
Premium Member
Postby JQL » Thu Aug 10, 2017 11:05 pm
When you save your image you have to choose an option that is called something like "Save Sketchup Image" It will save whatever is displayed in Sketchup viewport. If your render has Sketchup Edges turned on, it will save that image.
User avatar
JQL
Premium Member
Premium Member
Postby sfto1 » Fri Aug 11, 2017 8:14 pm
JQL,
Where can I find that option? I'm hunting now, but can't find it.
"Never mind. I found that option in the "save as type" pull down.
Thanks so much!!
User avatar
sfto1
Premium Member
Premium Member
Postby srx » Fri Aug 11, 2017 8:57 pm
The picture...
www.saurus.rs
User avatar
srx
Postby pbacot » Fri Aug 11, 2017 9:10 pm
Twilight renderer can do this. It's done as sort o post-pro setting along with tone mapping etc. You can turn it off or on in your rendered image before exporting.
https://www.twilightrender.com/phpBB3/viewtopic.php?f=12%26amp;t=5421
MacOSX (El Capitan) ShetchUp Pro v16 Layout Twilight Pro v2 M2 Kerkythea PowerCADD
User avatar
Top SketchUcator
Postby sfto1 » Fri Aug 11, 2017 10:29 pm
pbacot wrote:Twilight renderer can do this. It's done as sort o post-pro setting along with tone mapping etc. You can turn it off or on in your rendered image before exporting.
Interesting.
User avatar
sfto1
Premium Member
Premium Member
Postby NigeC » Sat Aug 12, 2017 11:47 am
SketchAIR can also do it but the trial is limited to 1024x1024 and it hasn't had any love for a long time now.. shame really
“It’s only impossible if you stop and think about it!”
User avatar
NigeC
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Thea
Who is online
Users browsing this forum: No registered users and 2 guests
Visit our sponsors:
