2D Perspective and rendering?
• Page 1 of 1
2D Perspective and rendering?Is this possible with Podium? Im actually using the eval version currently... Im actually working on my first freelance job and im planning on reinvesting the money i earn back into the full version... And i was curious if the full version has the capability of rendering 2D Perspective??? THANK YOU ALL!!!
Re: 2D Perspective and rendering?When you say 2d Perspective do you mean 2point perspective? At the moment there is no difference between eval and full version but size of the rendered images.
Re: 2D Perspective and rendering?Woops... Im sorry your correct 2 point perspective!! If i zoom out it doesnt change in the render... For example if im trying to fit more of a room into the render...
Re: 2D Perspective and rendering?Now I am slightly confused. At moment 2 point perspective is not suported.
However if you are talking about wide angle to fit more things in your render you can change FOV (field of view). If you click on magnifier you will get number in your SU VCB. Change that number to smaller one and you will get wide lense. You can render with any number but 0. If you have value 1 you get something very close to elevation. Re: 2D Perspective and rendering?Ok... If i select 2 point perspective... and put my little guy in the corner of a room... and scroll out on my mouse... I can see more of the room with out going through the wall... And if i try to render that image... almost like a panaramic image... It doesnt render... It only takes a little bit of the full picture... (if that makes any sense?) But ill try to figure out what you said in your last post and see if that works? THANKS!!!
Re: 2D Perspective and rendering?2point perspective is not supported at moment. However if you wish to render wide lense follow the instruction above. It will allow you to be in the room and see more.
edit: we are looking into 2point perspective. Can't promisse you when it will be implemented.
• Page 1 of 1
