Solid Tools > Subtract  Topic is solved
The ideal place for beginners to get help using SketchUp
Postby ketchupu » Tue Nov 14, 2017 7:14 pm
Hi, I just started using Sketchup 2017 a couple days ago, and with watching some of the online tutorials, I have figured out how to use the the Subtract Tool with basic objects, like a smaller cube subtracted from a larger cube. However, I am having trouble subtracting this oval cylinder out of a curvy wall. I have converted both to separate components. Both components are Shiny with Solid Inspector v2. My ultimate goal is to print this out on a 3D printer. I have attached a screenshot and the skp file as well. Can some provide some insight into what I am doing wrong? Any help would be much appreciated.
ketchupu
Re: Solid Tools > Subtract
Postby juju » Tue Nov 14, 2017 7:25 pm
Solid Tools is a Pro only function. Your profile indicates that you are using Make, thus the tool will not be available. Unless you're using the trial of SU Pro, it should be available then.
juju
Premium Member
Premium Member
Re: Solid Tools > Subtract  Topic is solved
Postby TIG » Tue Nov 14, 2017 7:39 pm
You are running into the well documented 'tiny-geometry' limitations of SketchUp.
Sketchup regards points closer that 1/1000" apart as being coincident.
Thus tiny any such edges are not created and the faces they support are then missed.
The simple trick is to scale up the two parts x10 or x100 and then doing the subtraction.
When you have the desired form you can scale it down to the original size...
The tiny geometry can exist, but it can't be created directly.
Global Moderator
Postby slbaumgartner » Wed Nov 15, 2017 2:58 pm
ketchupu wrote:However, I am having trouble subtracting this oval cylinder out of a curvy wall.
Could you clarify what you mean by this? What sort of trouble are you encountering?
slbaumgartner
PluginStore Author
PluginStore Author
Postby ketchupu » Thu Nov 16, 2017 6:54 am
juju wrote:Solid Tools is a Pro only function. Your profile indicates that you are using Make, thus the tool will not be available. Unless you're using the trial of SU Pro, it should be available then.
Yes, I currently have the trial version for now, but it does include the Solid Tools function. I have tried everything including the Intersect Faces (in the Make version). I think I see the answer in the next reply ...
ketchupu
Postby ketchupu » Thu Nov 16, 2017 6:57 am
TIG wrote:You are running into the well documented 'tiny-geometry' limitations of SketchUp.
Thanks a lot! This makes a lot of sense. Even with other models I have made, I have been pulling my hair it with tiny imperfections around curves that appeared somewhat randomly
ketchupu
Postby ketchupu » Thu Nov 16, 2017 6:58 am
One or both objects would disappear, or there would be lots of imperfections (missing faces) in the resulting structure.
ketchupu
Return to Newbie Forum
Users browsing this forum: Google Bot and 12 guests
