AO chanel - dysfunction ?
General discussion on Thea Render for SketchUp
Moderator: Frederik
Postby surprenant » Wed May 11, 2016 12:21 pm
Hello,
I have some questions about possible dysfunction of Thea render.
- Before the latest update of Thea render I had my AO chanel working well (with Adaptive BSD of course). But so far it is always black and I can't find what changed.
How do you do to make the AO chanel appear and work ?
- when I go for render, there is always a first time with just the color chanel working. Then I need to stop and to start again for having all the chanels chosen work.
Can I save time and have everything the first time ?
Thanks for your reply,
Gaelle
surprenant
Re: AO chanel - dysfunction ?
Postby tomasz » Mon May 16, 2016 12:12 pm
Default AdapriveBSD presets do not use AO.
If you want enable it, then you can crate your custom preset:
tomasz
SU2TH & SU2KT Developer
Postby surprenant » Tue May 17, 2016 8:58 am
Hello,
Thank you very much, that seems all clear... except that I can't see the new preset I renamed in the file Thea Data\Presets. It doesn't appear.
Do I miss a step ? Thank you by advance
surprenant
Postby tomasz » Thu May 19, 2016 10:35 am
surprenant wrote:Do I miss a step ?
Yes. The preset has to be moved/copied to plugin presets folder.
When you open Thea4SU main window, in the console you will read the location of the plugin folder. There is 'presets' sub-folder in it.
tomasz
Postby surprenant » Wed Jun 08, 2016 9:55 am
Thank you very much !
It works perfectly now !
...any idea of why I need to launch twice the render process to get the layers selected ?
Thanks again !
surprenant
Postby tomasz » Tue Jul 12, 2016 8:46 am
surprenant wrote:...any idea of why I need to launch twice the render process to get the layers selected ?
It looks like a bug. What version of Thea for SketchUp are you using? This was fixed some time ago. Have you tried 1.5.07.444.1442 that was published in Thea forum?
tomasz
Postby surprenant » Mon Dec 12, 2016 10:54 am
Actually i get the same problem here on another computer, I follow the instruction of the tutorial but the preset I just saved with a new name never appear in my C:\ProgramData\Thea Render\Presets as an .xml file. It does exist in my thea studio presets though, so it has been well-saved.
Can you unlight me on that problem ?
surprenant
Postby NigeC » Mon Dec 12, 2016 8:35 pm
Try looking here:
C:\Users\yourname\AppData\Local\Thea Render\Presets
“It’s only impossible if you stop and think about it!”
User avatar
NigeC
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Thea
Who is online
Users browsing this forum: No registered users and 2 guests
Visit our sponsors:
