Making a surface drape with Artisan, and need it to be a solid to use SU Solid tools afterwards on other geometry.
The Artisan geometry is the problem no matter what I do. Solid inspector points out border of geometry as the problem - but can not see any problems along the border of geometry. What am I missing ?
Artisan mesh to solid
• Page 1 of 1
Re: Artisan mesh to solid
If you are seeing border geometry it usually means there is a hole or your shape has no thickness.
A solid has to be a manifold shell of faces, a watertight container, otherwise it is just a mesh. There are other basics about solids but without seeing what you have it is all guesses. 23:9
That must be it - no thickness to my mesh - thanks ![]()
• Page 1 of 1
Who is online
