[Plugin Library] LibFredo6 - v14.3d - 21 Apr 24
@fredo6 said:
@tlehman914 said:
I deleted the material 'Tree Tex8.jpg', and all is working!!!!
In ColorPaint, you are supposed to load only plain text file (tabular value of colors: name, R, G, B), not images or material.
Understood. I didn't even know that I had done that...!? Thanks again!
@fredo6 said:
How did you install LibFredo6?
- Copying files?
- Sketchup Extension manager from a rbz
- Sketchucation ExtensionStore?
It seems one file is altered.
Tried all 3 with full uninstalls in between each. Sadly no luck.
Success! Running a repair on the sketchup installation seemed to fix it!
Bonjour à tous,
Je viens d'installer l'extension FredoTools via le gestionnaire d'extension,
Elle apparait bien dans mon gestionnaire d'extension mais nul part ailleurs ?
Je ne peut donc pas l'utiliser.Il ya t-il une raison ou une manip particulière à effectuer ?
Je suis sur SketchUp 21pro
Merci d'avance
Have you also installed LibFredo ?
Have you restarted SketchUp ?
Have you looked in the Tools menu's submenus ?
Avez-vous également installé LibFredo?
Avez-vous redémarré SketchUp?
Avez-vous regardé dans les sous-menus du menu Outils [Tools]? -
I'm seeing some UI problems, specifically buttons at the bottom of various dialog boxes being completely washed out. I'm on MacOS Big Sur.
I don't have this problem in other applications, only here in SketchUp and with these dialog box buttons.
Any thoughts? Is it a SketchUp thing, an extension thing, or an OS thing?Please see image examples.
Thanks.
Thanks for signaling this problem. You are the first one.
Big Sur seems to be a master in term of non-backward compatibility, at least for Sketchup...!
I will see if I can find a workaround in a next version of LibFredo6.
Hello LibFredo6,
I recieved your message showing me your Pic2Shape plugin.
I tried it with a couple of images and it works great.
However, I would like to use this for cutting out the contours of 2D trees, so i can cast a more realistic shadow.
And here I ran into some troubles.
For complex trees (with a lot of tiny holes between the branches) the plugin says he can't generate any contours.
I wonder if you could help me with the right filter settings so that the plugin can still work ?I attached a tree (png) that doesn't generate a boundary when using the plugin.
All the png trees i'm using are available (for free) as high quality PNG’s with transparent background from this website : https://meye.dk/info/
Many thanks in advance !
Boris
Since this thread is about LibFredo6, I created a dedicated thread here.
Very efficient plugin thank you.
The only issue is that the colour of action icons are extremely difficult to read against the white background.
I am using SUP2021 on a MacBoo pro 2018 running under MacOS Mojave.Is it just me or a common issue that could be resolved easily on the developer's end?
Thank you.
T
This will be fixed in the next version of LibFredo6. This seems to happen for some Mac configurations.
NEW RELEASE: LibFredo6 v11.7a - 12 May 21
LibFredo6 11.7a includes
- bug fixing and various technical adjustments
NEW RELEASE: LibFredo6 v11.7c - 16 May 21
LibFredo6 11.7c includes
- bug fixing and various technical adjustments, mainly for Mac
I get no confirmation that my installation of updates (through the Extension Manager) does anything.
Is this to be expected?
SU Make 2017 -
Is this to be expected?What are you expecting to see? Extension Manager will show you the currently installed version of LibFredo6.
Fredo6's own Check for Updates will show you the currently installed version, too.
If you were using the Sketchucation tool to install it, you would get a notification through the tool that there is an update to be installed when there is.
@gregors said:
SU Make 2017
Your profile says you are using SketchUp 2015. Perhaps you would take a moment to update it?
Thanks I had not noticed the ">" which shows the version. All is good!
NEW RELEASE: LibFredo6 v11.8a - 02 Jun 21
LibFredo6 11.8a includes
- Support of the new extension LordOfTheToolbars v1.3a
HI Fredo ,
Have not been able to run the libfredo6 plugin successfully on Pro 2021
, tried reinstalling sketchup and re-down loading the plugin as per all the post feedback i could find on the web . Ps also no security access issues just to mention .I receive the following error message .
Error Loading File Fredo6_!LibFredo6.rb
Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:67:inprocess' C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:74:in
module:LibFredo6_Loader'
C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'Any assistance would be appreciated .
I think you have a wrong installation of LibFredo6.
Can you check you have a subfolder Fredo6_!LibFredo6 in your plugin directory, with a size of around 7 Mb.
NEW RELEASE: LibFredo6 v11.9a - 06 Jul 21
- Evolutions for LordOfTheToolbars v1.4a
NEW RELEASE: LibFredo6 v11.9b - 08 Jul 21
LibFredo6 11.9b includes
- Evolutions for LordOfTheToolbars v1.4c
