Could you help me how to solve my issue with dynamic components permanent indent? When I'm changing cabinet depth the indent is moving. The indent always should be 16 mm from back edge.
Dynamic Components
• Page 1 of 1
Re: Dynamic ComponentsResizing with Dynamic Components is a scaling operation. In your model you need to split the front part of the panel off the back as separate components. Then resize the back part and only move the front part with the groove. Maybe something like this.
I made it look like a single piece on the right by hiding the seam lines. Etaoin Shrdlu
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Thank you Dave for your tips. I did it but when I use OpenCut List plugin it shows me as two components. I want to have boths components to be as one part.Do you have an idea how to solve this issue? Re: Dynamic ComponentsExplode the two components and make a single one of the geometry before running Open Cutlist. Or skip the idea of making the cabinet a dynamic component.
Re: Dynamic ComponentsOpen cutlist does not understand the details with or without a groove. You will have to take this point into account yourself in the cutting.
Good point. Maybe the groove isn't necessary and could just as easily be omitted. I made a dynamic drawer box component specifically for use with Blum undermount drawer glides. It has no joinery details so in a cutlist the parts report correctly. It's also set up so a report can be generated for the drawer box maker to quote prices. They price by the numbers in the gray fields. Etaoin Shrdlu
• Page 1 of 1
