How to prevent texture from scaling  Topic is solved
Postby Scamparelli » Thu Jan 05, 2017 11:14 am
Hi all,
This is my first post on here, but may I say what I great forum - has been a massive help with my learning of SU Pro!
I need some advice on a problem I have with creating Dynamic Components with regards to Textures:
So I have created a simple component which resizes along X:
Set at 1500mm:
Set at 200mm:
As you can hopefully see, the Texture is rescaling, but I can't find a way to prevent this from happening..
Hopefully I am missing something quite obvious!!
Scamparelli
Re: How to prevent texture from scaling  Topic is solved
Postby Rich O Brien » Thu Jan 05, 2017 11:25 am
viewtopic.php?p=524808#p524808
much discussion about this over the years
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby pcmoor » Thu Jan 05, 2017 11:57 am
right click the component, then from the menu select make unique if there are other components at a different scale, and then select scale definition
pcmoor
Postby Scamparelli » Thu Jan 05, 2017 12:54 pm
Rich O Brien wrote:http://sketchucation.com/forums/viewtopic.php?p=524808#p524808
Thanks Rich,
This video helped the most (even though it is in Russian!): https://www.youtube.com/watch?v=TWGGfoR5slI
One thing to note, is that the texture must be applied AFTER you have followed this method. If you apply during creation of each element, it won't work..
Scamparelli
Postby toddster » Wed Jan 18, 2017 5:23 pm
I watched that russian video and I see that this work around works, i just cant figure out what he is doing exactly, can someone help explain it to me, i see him using a tool I dont have on my screen and then clicking over some of the faces of the cube but not all of them..sucks being a noob
toddster
Postby Rich O Brien » Wed Jan 18, 2017 10:04 pm
I thinks it's one of Jim's plugins. Not sure which though?
User avatar
Rich O Brien
Administrator
Postby goga63 » Sat Jan 21, 2017 10:11 am
This is my video (I used a method which is suggested Tig) . It's simple - inside the component, I put another component (scaler) and the prescribed attributes.
Scaler can be made invisible.
goga63
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Dynamic Components
Who is online
Users browsing this forum: No registered users and 2 guests
Visit our sponsors:
