file in use message
file in use message
Postby modelhead » Fri Feb 19, 2010 7:31 pm
When I update a google earth model from the 3d warehouse by clicking the "edit " button I get this warning and I am unable to save file changes...
@Gai...I know you helped someone with this before....can't find the post....cheers!
modelhead
Re: file in use message
Postby Gaieus » Fri Feb 19, 2010 7:54 pm
Hi Bruce,
This is weird. I don't presume you are using IE5 :shock:
BTW what happens when you answer yes, download the file and upload it again after the changes?
Postby modelhead » Sat Feb 20, 2010 8:54 am
Thanks Gai!
When I hit yes it opens but will not allow me to save it. I am using windows 7 although I remember it happening with XP as well. I've had the problem for some time..but instead of fighting with it I just delete the original. Of course that removes it from the earth layer. I had a pro licence once upon a time although it was such a pain to upgrade it I just deleted it and removed it's traces as well. (GE may be next..lol)
Is there a better method for updating...i.e. would it be better to just keep reloading the original from SU without going back to the warehouse. As I said it doesn't bother me but the google guys must get tired of promoting the same models over and over.
modelhead
Postby Gaieus » Sat Feb 20, 2010 3:45 pm
Use Jim's ModelID Plugin to set the model ID in any of your files (this is the number after the ?mid= sign in the URL of the model) and you can revise any existing model by updating the original file in the WH rather than uploading it as a new one (with obviously a new link).
Although normally the "download > edit > upload" method should work, there are often glitches so I still have this little gem at hand just in case.
http://sketchup.google.com/3dwarehouse/details?mid=94dd8c51d1053fcfe2d1c7fb74c7e53b
Postby modelhead » Sat Feb 20, 2010 4:43 pm
Thanks Gai!..I'll give it a try.
modelhead
Postby modelhead » Wed Feb 24, 2010 4:01 am
Thanks again Gai...that is a handy rb. I thought you might like to see it as it is a heritage building.
..and the link if you want to play.. http://sketchup.google.com/3dwarehouse/search?viewer=01688937678487232995&scoring=m
modelhead
Postby Gaieus » Wed Feb 24, 2010 8:41 am
Nice one! Smart detailing with png's!
It is a little bit floating however
Also, sometimes GE goes nuts when you save the file (before export) at such a sharp angle close to the ground. Not in this case but it's just on the edge of it.
Postby modelhead » Sat Feb 27, 2010 2:37 pm
I corrected this one and it was added within a couple of days. The image is SU output only. Thanks again Gai.
modelhead
Return to Google Earth
