Ruby not returning correct dimensions  Topic is solved
Postby Frankn » Fri Jul 14, 2017 6:04 pm
Sorry in advance for what may be a really noob question and I know I've seen this before but been away from scripting for a while and can't remember and can't find the solution by searching...
Basically if I have 3 components in my model each being 1/2" thick when I retrieve the components dimensions in ruby, 2 of them return 0.5 and one returns 0.4999999999999716. Why? and how do my fix that? I did try adding .to_l in my code but that didn't help.
Frankn
Re: Ruby not returning correct dimensions  Topic is solved
Postby TIG » Fri Jul 14, 2017 6:29 pm
0.4999999999999716" IS for all intents and purposes 0.5"
All computing code will have some approximation built in to it.
SketchUp's is 1/1000"
That's 0.001"
So quite clearly 0.4999999999999716" is equivalent to 0.5" for all practical purposes.
If you need to output the value and you are unhappy with the 'nearness' there are code method to return a user expected 'dim value'...
User avatar
Global Moderator
Postby Frankn » Mon Jul 17, 2017 11:46 pm
Thanks for the reply and clarification Tig!
The issue I'm having is that I'm using group_by to group by thickness but since the values don't match group_by doesn't work. So knowing what you just explained I'm using 0.4999999999999716.round(6) and that seems to do the trick. I use (6) because some values in inches have six digits after the .
If there's another way fix this issue please let me know.
Frankn
Postby TIG » Tue Jul 18, 2017 10:15 am
You have found your own solution.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: MaximumRisk and 5 guests
Visit our sponsors:
