A home Office in a Square Metre!
Dave, I forgot to mention that there will be an option in the cut-out to have a higher back support with two cross support members with nodes. Here is a pic of this StitSeat version.
I should also mention that the cushion can be one of many orthopaedic memory foam cushions on the market these days. They all have a similar 'U' shape design.
The makers state that these particular types of cushions have many health benefits, a few of which are,
Memory foam sciatica cushion, even if you sit for longer, keeps you 'prototype' and increases blood flow while maintaining support.
Soft seat cushion is suitable for Back Pain and Sciatica Relief, hemorrhoid pain or numbness from sitting, hurt tailbone, spine alignment, injured disc, Piriformis syndrome, lumbosacral spondylosis, fibromyalgia, surgery recovery, improve posture.
The surface of the back support cushion is ergonomically contoured to distribute your body weight across the seat. This wedge cushion reduces pressure on the tailbone, help ease the pain sciatica lower back pain discs and vertebrae throughout the spine.
I'm definitely not too sure about all these claims and would be inclined to take some of them with a grain of salt but there appears to be an amount of positive reviews.
Again, interesting concept. Would it be possible to have an optional pad for the back rest as well?
Your doing some interesting design concepts Mike.
Alas... I too am claustrophobic. But I think you could do a claustro version by simply removing the end panels and have the shelves cantilever. If not, you could consider removing the panels above desk height.
I love the chair. Well thought out.
Dale -
Yes, it would be possible and I have given the possibility some thought. The situation as it is currently has a lateral back rest support with two 'nodes'. From research it seems that these nodes can be therapeutic. Still, I take your point and will look at ways of incorporating a back rest cushion.
DaleThanks Dale, I take your point. I think it may be a possibility to have the section of side panel which would be to the left of a right-hand user, attached to the folding doors. I really would like to retain the ability to close off the unit when not in use.
I will do a version when I have time over the next few days.
It's a piece of genius design frankly, very nicely done Sir.
Well thanks Mike, all praise humbly accepted.
I have now modified the workstation design to accommodate those amount us the are somewhat claustrophobic.
The following images show the changes.
This image show a modification to the left-hand panel. The panel is now in two sections, the lower part is attached to the base plate and the upper section is attached to the bi-fold doors.
I am still making use to the corner brace. Now it has become a simple lock with a handle. While is adds no real security it does prohibit kids from getting in too easily.
This image shows the lock lifted.
This image show the bi-fold doors opening, now with the half panel.
This image shows a far more open working area with a rounded corner to the lower panel.
The Roll Out is now more beneficial as the user will now be able to view reference pages on the extended page holder more easily....also easier to grab their mug of coffee!
This is an enlarged view of the working area.Thanks guys for your very constructive comments / suggestions. I will continue to work on the StitSeat back and see if I can locate a suitable cushion.
Very nice revision Mike. In essence I think that both versions of the product design are viable. Very well thought out.
Off topic, but have you ever heard of Desall. They hold design contests, sometimes with very substantial prizes. I note this because they currently have a contest sponsored by a company called Sassi. It is for a modular furniture display system for children's books. Your work here on the modular desk reminded me of this.
Cheers
Dale -
Cheers
DaleThanks dale. I checked out that link for Desall and it look very interesting. Also the prizes are quite good, €3,000 and €2,000! Those amounts are very respectable. I read the design brief and am giving it some thought.
Over the weekend I was preparing the Tool Paths and Layouts for the CNC. This process is a pain trying to squeeze the various parts into the 1220x2440 sheets with 25mm (min) margins.
[attachment=6:142bus7d]<!-- ia6 -->StitSeat Extended & Adjustable Work Top A.jpg<!-- ia6 -->[/attachment:142bus7d]
I managed to get the StitSeat Combo (Workstation and Roll Out)into 3 Sheets. The StitSeat took up a half sheet. However the guys that provide the service provide full sheets so I thought about how I might fill the remaining half sheet. I decided on providing an extension to the StitSeat and a small Adjustable Work Top. The work top can be set up from 900 to 980mm over floor level.
This gives the option of just CNCing a single sheet that provides a basic Workstation, StitSeat and Work Top.
Here are some pics of what I have come up with.
[attachment=5:142bus7d]<!-- ia5 -->StitSeat Extended &. Adjustable Work Top 01.jpeg<!-- ia5 -->[/attachment:142bus7d]
[attachment=4:142bus7d]<!-- ia4 -->StitSeat Extended &. Adjustable Work Top 02.jpeg<!-- ia4 -->[/attachment:142bus7d]
[attachment=3:142bus7d]<!-- ia3 -->StitSeat Extended &. Adjustable Work Top 03.jpeg<!-- ia3 -->[/attachment:142bus7d]
[attachment=2:142bus7d]<!-- ia2 -->StitSeat Extended &. Adjustable Work Top 04.jpeg<!-- ia2 -->[/attachment:142bus7d]
[attachment=1:142bus7d]<!-- ia1 -->StitSeat Extended &. Adjustable Work Top 05.jpeg<!-- ia1 -->[/attachment:142bus7d]
[attachment=0:142bus7d]<!-- ia0 -->StitSeat Extended &. Adjustable Work Top 06.jpeg<!-- ia0 -->[/attachment:142bus7d]
Very clever design.
^ He is completely correct, making design this relevant look this good takes some doing, if it does not sell like hot cakes folk are missing something.
