SU turns off every 5 minutes
Hey,
I have SU 2017 and my friend sent me file created in SU2015. Now, it doesn't matter, what I open SU turns off every 5 minutes...
I tried to find help on forums and I've tried almost everything - reinstalled it, installed SU2015, reinstalled plugins, I removed C++ and installed Visual C++ 2015 redistributable. Nothing works, it is still the same.
Does anybody know what should I do?
Please, help me. -
Are you opening the same 2015 file in all instances of SU “shutting down”.
Describe shutting down in more detail:
Does SU simply close without any message/error?
Is there a bugsplat?
Does it freeze for a while and then close?
Etc.Etc.Have you tried turning off auto-save?
The more detailed info you provide....the better the help you will receive.
C
