by thomthom » Fri Feb 22, 2013 4:29 pm
OverviewAdds a Scale Definition menu item for groups to match the native function for components. ScaleGroupDefinition.png AccessGroup > Context Menu > Scale DefinitionRequirementsGuide: How to install RBZ FilesDownload Guide to installing SketchUp PluginsFootprint <Sketchup>/Plugins/ +-
tt_scale_group_definition.rb
- PluginStore Author
- Name: Thomas Thomassen
- Operating system: Windows
- SketchUp version: 2019
- License type: Pro
- SketchUp use: other
- Level of SketchUp: Advanced
by Rich O Brien » Fri Feb 22, 2013 4:43 pm
Rich O Brien
- Administrator
- SketchUp version: 2022
- License type: Pro
- SketchUp use: engineering and mechanical design
by Chris Fullmer » Fri Feb 22, 2013 4:52 pm
Cool Thom, thanks!
- SketchUp Team
- Name: Chris Fullmer
- SketchUp version: 2013
- License type: Pro
- SketchUp use: landscape architecture
by dtrarch » Fri Feb 22, 2013 7:20 pm
TT
FYI: SU 8 PRO latest Only shows for components and no menu on selection ( rt clk) Does not show on groups selected (contex rt click) Does not show in plugins/tt menu (all tt others do) TT lib 2.7.1 file exists in SU plugins ?
dtr
dtrarch
- Premium Member
by thomthom » Fri Feb 22, 2013 7:50 pm
Did you install the RBZ package properly? If you only copied the RBZ file to the plugins folder you did it wrong. See link under download button.
- License type: Pro
by dtrarch » Fri Feb 22, 2013 9:27 pm
Hi TT
Yes installed properly as below Installed using SU Windows/preferences/System preferences etc As required for .rbz plugins
dtr
dtrarch
- Premium Member
by dtrarch » Fri Feb 22, 2013 9:42 pm
TT
Double check .rbz install confirms install but does not show-up in the extensions list. When the .rbz is re-named .zip and opened only the .rb file is there. No tt_folder exists or icons
dtr
dtrarch
- Premium Member
by thomthom » Sat Feb 23, 2013 1:06 am
It is not supposed to appear in the Extension list - didn't implement that feature. It also doesn't have any support folders, it's just the .rb file. There is only one menu item, when you right click a single group.
- License type: Pro
by dtrarch » Sat Feb 23, 2013 1:28 am
TT I created 2 groups 1-solids 2-non solid Rt click on either shows your menu grey'd out here is the file dtr
dtrarch
- Premium Member
by thomthom » Sat Feb 23, 2013 1:41 am
Yes? Everything is working exactly as expected. None of the groups are scaled, so there is no way it can scale the definition.
I suspect you might be expecting a different result from what this plugin actually does.
Have you used the native Scale Definition feature that is available to components?
- License type: Pro
by dtrarch » Sat Feb 23, 2013 3:05 am
TT
Right on OK now
Apologies for all the fuss.
Someone scrubbed a previous reply.
Thx a bunch
dtr
dtrarch
- Premium Member
by bagatelo » Wed Jul 24, 2013 2:14 pm
This plugin can be used for entire scene? This is because your plugin "CleanUp" sometimes delete faces and edges too small...
bagatelo
- Name: Alex Henrique
- SketchUp version: 2015
- License type: Pro
- SketchUp use: interior design
by thomthom » Wed Jul 24, 2013 3:17 pm
No, it works only on selected group. But can you not use the Tape Measure tool?
Sent from my LT25i using Tapatalk 2
- License type: Pro
- Robot
Return to Plugins
