Possible for multi delete of these within a few click?
Get 3D Printing support, tips and tricks for SketchUp
Moderators: d12dozr, dukejazz
Postby sketchartist023 » Tue Dec 31, 2019 3:20 am
I was wondering if it is possible in sketchup, either natively or through a plugin of sort, to delete multiple (sometimes more than 40) internal faces of an isocontour rather than inside of a 3d model.
The faces that are not highlighted, for example, around a larger face with detail. Kind-of "secondary" internal faces if properly put.
Maybe even more than secondary as well, idk. Just thought of this today to try to see if I can speed of a process, instead of highlighting all then delete, or individual, etc.
Thank you :)
Here is a snapshot of an example I would like to test it on:
User avatar
sketchartist023
Re: Possible for multi delete of these within a few click?
Postby Box » Tue Dec 31, 2019 3:26 am
You can do Triple click to select all then shift double click to deselect the face and all it's edges that you want to keep and delete the rest.
A simple example.
User avatar
Postby sketchartist023 » Tue Dec 31, 2019 3:36 am
Box wrote:You can do Triple click to select all then shift double click to deselect the face and all it's edges that you want to keep and delete the rest.
That sounds very workable, thank you :) Ill try it now and I figured it could be done internal so should work :) Thanks again!
User avatar
sketchartist023
Postby sketchartist023 » Tue Dec 31, 2019 3:37 am
It worked quite well thank you very much. I kne the +/- was good for both plus and minus somehow :P
Hope all is well!
User avatar
sketchartist023
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp for 3D Printing
Who is online
Users browsing this forum: No registered users and 0 guests
Visit our sponsors:
