Sketchup Export in Weird Formats
General discussion related to SketchUp Pro and Make
Postby david_h » Mon Jun 17, 2019 8:43 pm
I have a consultant who has asked for a model to be sent to him in 3D as either STEP, IGES or X_T?
This is for 3D printing or metal fabrication, I guess. Anybody know if this can be done?
Thx in advance.
David_H
If I make it look easy. . .then it probably is.
User avatar
david_h
Top SketchUcator
Re: Sketchup Export in Weird Formats
Postby Dave R » Mon Jun 17, 2019 9:20 pm
Commonly for 3D printing, STL is the file format to use. You can export those directly unless you are using an older version and then there's an STL exporter available in the Extension Warehouse. I've done a bit of searching but not turned up any exporters for step, iges or X_T. Maybe they could work with 3D DWG files?
User avatar
Global Moderator
Postby david_h » Mon Jun 17, 2019 9:54 pm
thanks Dave. I did do some of that. I guess these are formats for Solidworks. I did try exporting skp to 3ds to Iges, or whatever. Didn't work. STL was no problem. Why it was not useful to him I have no idea. But i sent him all the formats I could told him he's on his own. . . so there! :mrgreen:
User avatar
david_h
Top SketchUcator
Postby sketch3d.de » Tue Jun 18, 2019 12:52 pm
because NURBS modelers need exact surfaces made of curves transported by common NURBS 3D CAD formats as STEP or SAT (Acis) or IGES (worse) or the native format of the destination application instead of the facetted meshes created and exported by SketchUp which are more or less worthless for a further use in a NURBS modeler.
User avatar
sketch3d.de
Postby david_h » Tue Jun 18, 2019 3:12 pm
Sketch3D: thank you for the input.
I didn't understand a single word of that. :mrgreen:
User avatar
david_h
Top SketchUcator
Postby sketch3d.de » Tue Jun 18, 2019 4:02 pm
david_h wrote:I didn't understand a single word of that
...and you are proud of it :ecstatic:
User avatar
sketch3d.de
Postby david_h » Tue Jun 18, 2019 4:35 pm
Yes. Yes I am. ;)
User avatar
david_h
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: fred.dy, Google Bot and 9 guests
Visit our sponsors:
