Perfect Isometric View in Sketchup
Is it not the same as menu:
Camera\Standardviews\Iso
wow, now I feel like an idiot.
But yes, you're right. Lets just say that the metod I showed allows you to do an ISO view in the direction you prefer...
Hm, the Sketchup function let you do this also.
Rotate fairly into the wanted view and choose ISO and it will be aligned exactly into the prefered view. -
For diametric and other view Stuff
From the Eboy site!
Rotate fairly into the wanted view and choose ISO and it will be aligned exactly into the prefered view.I did not know that, that's why I came up with my solution
thanks for pointing it out for me..
by HPW ยป Thu Oct 11, 2012 11:17 pm
Rotate fairly into the wanted view and choose ISO and it will be aligned exactly into the prefered view.Haha that's something i completely overlooked. Thanks for the tip.
Got one more question about this:
The Architecture projects i work on are mostly world orientated so they don't follow the sketchup basic axes.
When i change the axes to follow the direction of the building and i want that view in isometric view. sketchup still shows the isometric view based on the basic axes.
Do i something wrong here? or is that the only restriction that your model has to follow the basic axes. -
Do i something wrong here? or is that the only restriction that your model has to follow the basic axes.In this case I imagine that my solution should work, but you would have to try it out
Thanks for the awesome tip - just what i need for some iso architectural diagrams!
TIG also has created a great plugin for both Axometricand Isometricviews which can be found in the link below:
http://sketchucation.com/forums/viewtopic.php?t=29018
I've found this invaluable in my workflow
Perfect!! Very thank much you!!
Perfect
Thank you SOOOOO MUCH!!!!!
This is exactly, what I was searching for! Thanks for sharing the tip!
