Real world model entirely modelled in Sketchup
Postby pieterv » Sun Dec 30, 2012 3:40 pm
Hello Folks,
I would like to share a video I've made. It is done by using the stop-motion thechnique. All the different parts are modelled in Sketchup first. I have counted them: there are 1845 different parts in total. The model is about 1m25 in heighth and at the floor it is about 1m50 x 1m50. It is build to scale 1/200, so in reality the building would be about 240 meters tall.
Here is a link to the video on Vimeo (for higher resolution): https://vimeo.com/38913543
User avatar
pieterv
Re: Real world model entirely modelled in Sketchup
Postby pbacot » Sun Dec 30, 2012 6:50 pm
Astounding work! I would like to see more "behind the scenes".
(The beginning reminded me of "Metropolis" and early stop motion animation --should've stuck with that dramatic opening music. :) )
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
User avatar
Top SketchUcator
Postby cotty » Sun Dec 30, 2012 7:15 pm
WOW! Impressive video. How long did you work on this? Did you lasercut the parts?
User avatar
cotty
Top SketchUcator
Postby orgelf » Mon Dec 31, 2012 10:40 am
excellent work ! :enlight:
nice use of the snowflake :D
User avatar
orgelf
Postby pieterv » Mon Dec 31, 2012 1:55 pm
Thanks! :-)
@ Pbacot: I'll add some more 'behind the scenes' materials. I think you have a good point: I could have stuck with the dramatic (North-Korean) opening music, but it was not so easy to find a piece of classical music that would fit because of the high tempo of the footage. My knowledge on different genres of music is not so great, so if anyone has a suggestion, it's always welcome!
@ Cotty: I worked on the project (from the first sketches to the final result) for about a year (mostly in the weekends). Yes, it is lasercut.
@ Orgelf: Thanks!
Here is a video where you see how I cut angled corners onto the different pieces. (Do not try this at home actualy. :-) I am not following the safety instructions closely). You can find more pictures on my blog ( http://pietervermeersch.blogspot.be ) but I'll also add some pictures here:
About 1845 parts in total.
Sketchup construction drawings:
First sketches
User avatar
pieterv
Postby d12dozr » Mon Dec 31, 2012 3:50 pm
Crazy cool! I think it deserves a place in the Sketchup Showcase: http://showcase.sketchup.com/ Have you thought about submitting it there?
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Postby pbacot » Mon Dec 31, 2012 5:26 pm
...yes and "most impressive sketchup modelling" thread!
User avatar
Top SketchUcator
Postby pieterv » Thu Jan 03, 2013 2:05 pm
@d12dozr: Thanks for the tip! Maybe I'll just do that!
User avatar
pieterv
Postby pilou » Thu Jan 03, 2013 3:01 pm
Constructivism revival! :enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby pieterv » Thu Jan 17, 2013 10:09 pm
Here is another project where I have used Sketchup to make the illustration and the construction. You can find more photos here: http://pietervermeersch.blogspot.be/201 ... ct-m2.html
User avatar
pieterv
Postby notareal » Sat Jan 19, 2013 9:10 am
pieterv wrote:Here is a video where you see how I cut angled corners onto the different pieces. (Do not try this at home actualy. :-) I am not following the safety instructions closely).
Quite job... I was thinking that this must be done with laser cutting ;)
notareal
Thea Render Support
Thea Render Support
Postby pieterv » Wed Sep 04, 2013 9:04 am
Hey Notareal,
All the peices are done with lasercutting, but I have done the angled corners with the saw. :-)
User avatar
pieterv
Postby Tobobo » Wed Sep 04, 2013 10:36 am
That is very nice work.
Did you use layout to arrange the pieces for the laser cutter?
Toby
Philippians 4:13
User avatar
Tobobo
Postby pieterv » Wed Sep 04, 2013 10:50 am
Hey Tobobo,
Thanks, I have used illustrator to arrange the pieces.
User avatar
pieterv
Postby Tobobo » Wed Sep 04, 2013 10:59 am
pieterv wrote:Hey Tobobo,
When I did my MA, I used Illustrator to do the same thing but then had to eps it. As the driver only worked through Corel Draw.
Toby
Philippians 4:13
User avatar
Tobobo
Postby Krisidious » Wed Sep 04, 2013 12:20 pm
That is AWESOME Pieterv... :berserk:
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Postby boofredlay » Wed Sep 04, 2013 4:01 pm
:shock:
Great work.
User avatar
boofredlay
Global Moderator
Postby cadmunkey » Thu Sep 05, 2013 9:45 am
Insanely brilliant!! Wow. :thumb: :o
cadmunkey
Postby tomasz » Sat Sep 07, 2013 7:58 pm
Great patience and excellent result! I admire your passion for the design & construction.
tomasz
SU2TH & SU2KT Developer
Postby pieterv » Sat Oct 05, 2013 8:54 am
@ Boofredlay:
@ cadmunkey:
@ Tomasz:
Thanks a lot! :-)
User avatar
pieterv
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Gallery
Who is online
Users browsing this forum: psylo and 2 guests
Visit our sponsors:
