[Plugin] Display Latitude & Longitude
Postby Didier Bur » Sun Sep 26, 2010 9:06 am
A friend requested this small tool so here it is: assumed your model is georeferenced, click a point and you'll get the latitude/longitude coordinates of this point (decimal format).
Thanks to TIG for helping me on this ;)
Install: drop it in Plugins folder
Usage: Select "Latitude/Longitude of point" from the Tools menu, and pick a point.
French and english versions available on RLD:
http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=737
Regards,
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
User avatar
Didier Bur
Re: [Plugin] Display Latitude & Longitude
Postby simon le bon » Sun Sep 26, 2010 9:45 am
Dear Didier,
It would be cool to see you more often ;)
Thank you for this one. I think georeferencement is in the smell of the times. Something which is going to be a sort of revolution. Everybody, everything is going to need to be georeferenced. IMO as a consequency, a revolution in the minds. Like Japanese people we are on to consider that the same object my car for example, is not the same object when it is not at the same place......
In case Here is a Motions of the Sun Simulator a tool indicated by Dale
Cheers, simon
User avatar
simon le bon
Postby mike8213 » Thu Nov 04, 2010 5:29 pm
Didier,
Fantastic plugin. Is there a plugin that you know of that could do the opposite. Insert a point or ray at a known lat long position.
Regards,
Mike
mike8213
Postby Didier Bur » Thu Nov 04, 2010 9:12 pm
No, but that's do-able.
Didier Bur
User avatar
Didier Bur
Postby mikestone » Wed Jan 01, 2014 6:02 pm
can you explain how this is do-able or attach a plugin?
mikestone
Postby mac1 » Wed Jan 01, 2014 7:05 pm
mike:
SU and Goolge Earth uses the WGS 84 datum ,but not all locales do world wide. So at any time make sure you under stand what datum you need to be working with.
mac1
Top SketchUcator
Postby davecoopstl » Tue Apr 05, 2016 3:50 am
Didier,
Is it possible to make this extension return the Sea Level ELEVATION, in addition to the Latitude and Longitude, if the model is geo-located?
We often design our sites from land surveys, which provide spot elevations (height above sea level). It would be great to locate those spot elevations on the site in SketchUp as well.
If not, do you know of an extension that can return the geo-located Sea Level Elevation, similar to how your extension returns the Latitude and Longitude?
Hope you can help.
Thanks.
Dave.
davecoopstl
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: asma98 and 14 guests
Visit our sponsors:
