SketchUcation Premium Membership
[Plugin Beta] Curviloft 1.2d - 13 Apr 12 (Loft & Skinning)
Postby fredo6 » Thu May 27, 2010 12:00 am
IMPORTANT: Curviloft plugin is still released in BETA and has no documentation yet. Please be aware of potential crashes and therefore always save your work before launching it.
In Beta version 1.2d, all three modules Loft By Spline, Loft Along Path and Skinning should be functional. I still need to complete many features.
Curviloft is a script dedicated to Loft and Skinning, that is, generation of surfaces from contours.
  • Loft by Spline joins separate contours, open or closed, by smooth splines
  • Loft along Path joins contours, along a given rail curve.
  • Skinning create surfaces bounded by 4 or 3 contiguous contours
Because there are many solutions to calculate Loft and Skinning geometries, the script offers various options to adjust parameters depending on the configuration of contours.
Curviloft 1.2d – 13 Apr 12
Curviloft 1.2d - 13 Apr 12.zip
IMPORTANT: Requires to download LibFredo6 4.2 or higher if not already installed.
No user manual written yet
  • Sketchup versions: SU6, SU7, SU8
  • Platforms: Windows and Mac
  • Language: English, Spanish (To all kind translators: please do no start translation yet)
  • Menus: by default, it is installed in Tools > Fredo6 Collection > Curviloft
  • Icon toolbar: by Default ‘Curviloft’. Three icons are available, but you can configure which ones to display (menu Default Parameters…)
  • The plugin is free, for private and commercial usage. There is a donation menu however.
1) Download and Open the archive
2) Select All (Ctrl A)
3) Extract into the Sketchup Plugin Directory
4) Answer Yes to overwrite former existing files if any
The footprint in the SU Plugin Directory must be:
C:\Program Files\Google\Google SketchUp 8\Plugins
- LibFredo6.rb
- LIBFREDO6_Dir_44
- CURVILOFT_Dir_12
Note: there is no need for the file ZLoader__Curviloft.rb with LibFredo6 4.2
On Mac the SU plugin directory should be:
Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
CAUTION: NEVER rename or move files from their folders. If you are unsure of your unzip operation, do it in a neutral folder and check that you reconstruct the right footprint. Then transfer the folders and files to the SU Plugin Directory.
CONFLICT With Sunposition.rb: there is a conflict with a plugin called sunposition.rb, by Gabriel Miller at Cerebral Meltdown. If installed, it will cause a crash of Sketchup when going to Preview mode in Curviloft. (more details on solving the conflict)
Overview
Tutorial on Loft by Spline
Loft Along Path
There is also an impressive tutorial made by Charly2008, showing how to draw golden rings, crowns and all sort of twisted objects.
see http://forums.sketchucation.com/viewtopic.php?f=18&t=29374#p256385
LOFT by SPLINE
  • Pre-Selection mode (automatic ordering): Select one or several contours (faces, edges) and Click on the icon
  • Manual Selection (user-specified ordering): Click on the icon and then pick contours in order. Click in empty space to separate contours when contiguous. Then click again in the empty space when done with the selection
  • In preview mode, you can adjust parameters via the main button palette (global setting) or the floating palette (individually by section). You can also modify vertex matching by selecting a vertex and dragging it to a new position.
  • Click in the empty space to validate and generate the shape geometry.
  • You can go back to Preview mode via the roll-back button
  • It is a good idea to check the tooltips and contextual menu to see available options
LOFT along PATH
  • Select the path and click in the empty space (it should be highlighted in thick red)
  • Select the other contour(s) that should follow the path (currently it works with 1 or 2 contours)
  • Click in the empty space (or Return) to move to the Preview mode
  • you have three methods for generating the shape: Stretch (default), Offset and Sweep. See video for illustration.
    Offset and Sweep ensure a correct thickness of the shape and therefore are more adapted to models with closed contours and winding path. Stretch is based on deformation of the path curve by moving extremities.
SKINNING
  • Select the contours one by one (click in the empty space between two contours). Then click again in the mepty space to generate the preview shape. All cells should have 3 or 4 bordering contours.
  • Pre-selection mode works as well, but may not be able to handle ambiguous cases. Also, it is always a good idea to draw small open segments at the vertex which you want to use to separate contours.
  • you can play with the Interpolation and rail over-sampling to add / remove divisions in the mesh
Curviloft 1.2d – 13 Apr 12: Small update about diagonals to better guide the mesh construction in Thomthom's QuadFaceTools and ThruPaint. In all generation modes, diagonals in the mesh are now generated with property Casts Shadow = false, which is the convention for diagonals (invented by Thomthom). In version 1.2c, this was the case only if the Pseudo-quad option was selected.
Curviloft 1.2c – 15 Nov 11: Slight change for the generation of Quads, to align with new definitions used by Thomthom's QuadFaceTools - Border: Soft + Smooth (+ Cast Shadows)
- Diagonal: Soft + Smooth + NO Cast Shadows
Curviloft 1.2b – 26 Sep 11: Include more options in the Default Parameters Dialog box for generating pseudo-quads. By default, pseudo-quads are now generated with:
- Diagonal: Soft + Smooth + Hidden
See Release Notes for detail
Curviloft 1.2a – 21 Sep 11: Include the generation of Pseudo-quads allowing the usage of the new QuafFaceTools by Thomthom. Also, it avoids generation of empty group if there is a problem.
See Release Notes for details on pseudo-quads generation.
Curviloft 1.1c – 29 Jun 11: Fix to a bug concerning mean internmediate curves when the contour are closed loops. Thanks to Defisto for signaling this issue
Curviloft 1.1b – 27 Jun 11: small upgrade to help generating mean curves between contours. This is done by an additional options for geometry, so that you can just draw Junction lines, intermediate lines or both (i.e. mesh) without the faces.
See this post for discussion about the feature.
Curviloft 1.1a – 12 Jan 11: Fourth beta version, dedicated to Loft Along Path. Main evolutions are:
  • Some fixes in Loft by Spline and Skinning.
  • Loft Along Path should be functional and handle 1, 2 or more contours with 3 methods: Stretch, Offset and Sweep
  • Two-phase loading of the script
On top of potential bugs and geometry issues (including bugsplats), there are still some limitations and unfinished work:
  • VCB is not active
  • No interactive edition in the floating palette
  • B-Spline and F-Spline do not close nicely in loop mode
  • No later reedition of shape generated (this will come)
  • all texts and labels are not reviewed yet
Curviloft 1.0c – LibFredo6 3.5c – 20 Aug 10: Third beta version, dedicated to fix bugs in Loft by Spline and Skinning. Loft Along Path is still not fully functional.
Curviloft 1.0b – LibFredo6 3.5b – 11 Jul 10: Second beta version.
Curviloft 1.0a – LibFredo6 3.5a – 13 Jun 10: First beta version.
Top SketchUcator
Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)
Postby Rich O Brien » Thu May 27, 2010 12:06 am
Hi Fredo,
Great to hear it's getting close to release! The video is amazing :shock:
Will post back with examples for testing
Thanks for sharing
Rich
:::Blog:::
I'm a Trimbler now!
User avatar
Rich O Brien
Administrator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Level of SketchUp: Advanced
Postby Daniel S » Thu May 27, 2010 12:18 am
:sketchstatic: :sketchstatic: :sketchstatic:
Fredo!!!
you are a genius!!!
I don´t know if something like this one will work...
but here I attach a panton chair.
I have to see this video again and again :bounce: :bounce:
Daniel S
Daniel S
Postby fredo6 » Thu May 27, 2010 12:39 am
Daniel S wrote:I don´t know if something like this one will work...
Daniel S
Daniel,
I had to put some splitter (i.e. line) to get contours with 4 parts.
Here is the file and a short video.
Top SketchUcator
Postby Daniel S » Thu May 27, 2010 12:55 am
Looks like it is the most powerful plugin ever made. :sketchstatic: :sketchstatic: :sketchstatic:
Daniel S
Daniel S
Postby utiler » Thu May 27, 2010 1:04 am
I feel like a kid at christmas time who knows what he's getting but can't open his present yet!!!!
You never seem to amaze, Fredo!
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby JClements » Thu May 27, 2010 3:33 am
WOW! Way to go!
Any chance, once a skin is made, that could be some axial controls that could be dragged to do stretching such that the skin would react like what is done in Soapskin and Bubbles where the forming edges are anchored and the skin stretches relative to the forming edges? Perhaps have a tightness parameter to control how close the skin conforms to a path or to the defining edges? Could the path be altered interactively to reshape the skin?
Tapering. Really would like to create Reduced Elbows for Piping or Ducting systems. Draw a "welded" curve for a path, place circle or "donut" tangential at each end of the path with specific radii/diameter and then form the skin of pipe (inner diameter as well as outer diameter too?). Have a means to minimize the amount a faces formed. Transitions of the ribbing of pipe would be linear versus what looks like an averaging method used in your video for "freeform" skins. It would be fantastic if the end diameters were parametric so user could change their values.
John
John
Illustrator
Beaverton, Oregon
User avatar
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Level of SketchUp: Intermediate
Postby EscapeArtist » Thu May 27, 2010 3:38 am
Looks fantastic, really looking forward to seeing the finished product in operation.
User avatar
EscapeArtist
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby EarthMover » Thu May 27, 2010 3:51 am
Holy crap!!! Is that speed realtime? Looks amazing! Do the number of segments in the rails matter? Could this possibly be used to replace the standard from contours in the sandbox tools to create graded terrains?
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
User avatar
EarthMover
Top SketchUcator
Postby xrok1 » Thu May 27, 2010 5:18 am
WOW! i love how you ruby greats are dragging SU kicking and screaming into the realm of a "real" 3d modeling program! :ecstatic:
screw you google. if you won't give us proper tools someone will. :twisted:
thanks Fredo, and everyone; TIG, ThomThom, Chris, Jim, Dedier, Whaat... just to name a few. you guys ARE the real SU team. all we really need from google is poly support. you guys cover the rest.
xrok1
Postby vidy » Thu May 27, 2010 7:19 am
BRAVO FREDO :bounce:
still so much to learn..
vidy
SketchUp version: 8
License type: Pro
Level of SketchUp: Beginner
Postby Panga » Thu May 27, 2010 7:46 am
Really big thanks for investing so much time to give us so niceeeee plugins !! I'll try to post a file to test it on terrain modelling, which is my main occupation in SU.
Panga
Premium Member
Premium Member
Postby thomthom » Thu May 27, 2010 7:47 am
Looking very nice. Can one edit the control splines afterwards?
1:24 - Float Pal window: is that done using view.draw* method?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Thu May 27, 2010 8:14 am
The Fredo return! :fro:
What a teaser! :ugeek:
What about make a thickness to a surface?
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Postby fredo6 » Thu May 27, 2010 8:26 am
Pilou wrote:The Fredo return! :fro:
I guess this is a job for JPP. Curviloft only generates the thin surface.
Top SketchUcator
Postby Pilou » Thu May 27, 2010 8:40 am
JPP : the "Jean Pierre Papin des surfaces" ;)
( a famous French footballer ;)
Speedy Galerie
User avatar
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby fredo6 » Thu May 27, 2010 8:43 am
thomthom wrote:Looking very nice. Can one edit the control splines afterwards?
Tom,
Yes the button palettes are all based on view.draw methods. And for Curviloft, I had to introduce the concept of a floating palette to allow edition of each of the individual sections, as shown on this small video:
Top SketchUcator
Postby TIG » Thu May 27, 2010 9:12 am
As ever, a "tour de force".
Can't wait to try your new tools...
Very impressive interface and speed.
:bounce:
User avatar
Global Moderator
SketchUp version: 2013
License type: Pro
Postby CadFather » Thu May 27, 2010 9:57 am
sugar.. everytime Fredo starts these things, it's like another copernican revolution! :lol:
Quarr-IT - SketchUp Training from the Master.. . ;) .
User avatar
CadFather
Name: Max Coppoletta
Postby thomthom » Thu May 27, 2010 10:00 am
Fredo6 wrote:And for Curviloft, I had to introduce the concept of a floating palette to allow edition of each of the individual sections, as shown on this small video:
Is that adjustments one makes before you end the tool? Or can you take a shape you created earlier and readjust it? On other words, is it parametric?
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby fredo6 » Thu May 27, 2010 11:30 am
It's difficult to make things parametric in Sketchup, because all you have at the end is faces and edges.
My plan to help a little bit would be to attach some information to the Component created so that you can reedit later on.
also, and already working is the possibility to generate the juctions as curves so that when you move the profiles, then the shape deforms accordingly (something that is shown in Kirill's scripts).
Top SketchUcator
Postby thomthom » Thu May 27, 2010 11:34 am
Yea - it was something like that I was wondering if it would do. Very promising!
Once I get Vertex Edit out of the way I want to make Bezier Path modelling tools. The control points stored as attributes for later edit-ability. Of course, if the user was to edit the geometry with other tools that would be ignored.
If the observers behave better in the next SU I want to make modifiers that one can apply to groups/components. Stack them up and apply the modifications after the user edit the base shape.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby notareal » Thu May 27, 2010 11:45 am
Stunning! What a return.
notareal
Thea Render
Postby Mike Lucey » Thu May 27, 2010 12:39 pm
I think I've figured out how Fredo is doing all this fantastic work ...... if you listen carefully to the video you will hear a lot of squeeking going on in the background ....... well these can only be Creative Gremlins! :thumb:
User avatar
Mike Lucey
Mayor
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby olishea » Thu May 27, 2010 2:25 pm
wow :shock:
oli
User avatar
olishea
Premium Member
Premium Member
Postby Jim Smith » Thu May 27, 2010 4:26 pm
Big thanks in advance for creating this plugin. :ecstatic: Frank Gehry will probably be switching to GSU pretty soon if Fredo keep this up :roll:
"Out of clutter find simplicity,
from discord find harmony,
In the middle of difficulty lies opportunity"
Albert Einstein
User avatar
Jim Smith
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby shura » Thu May 27, 2010 4:29 pm
Omg, we are drowning in pleasant anticipation!
User avatar
shura
SketchUp version: 7
License type: Pro
SketchUp use: interior design
Postby Rainie » Thu May 27, 2010 4:53 pm
Hi all,
where we can download this very helpful plugin!!! Thanks!!!
Rainie
Postby thomthom » Thu May 27, 2010 5:10 pm
Rainie wrote:Hi all,
When it is released. This was just a teaser. ;)
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Postby solo » Thu May 27, 2010 5:35 pm
Fredo strikes again!!
Looking forward to another true Gem.
My site
Quod gratis asseritur, gratis negatur.
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
by Ad Machine » 5 minutes ago
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: jinglebell, kaliphegtu, red cloud, sketch-gary and 2 guests
