Texture Resolution
I have an image at 1024 x 1024 = 173mm x 173mm @ 150 ppi (PS image attached)
If I create a material in SU which is 173 x 173 and place it onto a rectangle of any size then I believe the resolution will be 150 ppi (SU image attached)
If I change the size of the texture to say 86 x 86 mm then does that mean the resolution in Su is 300ppi?
thank you
