[RELEASE] Alpha 0.0.9
General discusson for Skatter for SketchUp
Moderator: jiminy-billy-bob
Postby jiminy-billy-bob » Thu Apr 09, 2015 9:08 pm
Alpha 0.0.9
Don't forget to restart Sketchup after install.
Nothing very exciting for you this time, I'm afraid. But I need you more than ever.
I implemented the licensing system. Here is the serial you can use : 6sblp-7GdCN-Z1Y3X-E0O4a
I need you to test if anything is broken.
Please try everything you can to break the licensing stuff.
After activating, the license file is located at C:\ProgramData\Skatter\License\license.lc
It's a txt file, you can open it and change stuff, delete it, etc. Be creative.
Thanks a lot for your precious time!
jiminy-billy-bob
PluginStore Author
PluginStore Author
Re: [RELEASE] Alpha 0.0.9
Postby jiminy-billy-bob » Thu Apr 09, 2015 9:14 pm
The licensing system is almost done only on the client side. I still need to do a lot of stuff on the server side. That's why I can give one serial for all of you at once.
This won't be possible in the future.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Rich O Brien » Thu Apr 09, 2015 9:57 pm
installed = ok
activated = ok
destroyed .lc file = error on next startup preventing using (ok)
pasted in licence = ok
net result = i couldn't break it
Rich O Brien
Administrator
Postby JQL » Thu Apr 09, 2015 11:01 pm
Jiminy,
Would you be interested if I would spread skatter on all computers around here?
I have two networks on one internet account and several different OS.
JQL
Premium Member
Premium Member
Postby jiminy-billy-bob » Thu Apr 09, 2015 11:04 pm
Not now, but definitly later when the server-side licensing system is done.
Thanks!
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Pixero » Fri Apr 10, 2015 7:20 am
Installation went fine here too. Will try to break it now...
Pixero
Postby caecarvalho » Fri Apr 10, 2015 1:52 pm
Instalation went fine here! Just noticed that it's not ready for v-ray 2.00.25539...But just changed the version in the vray.rb file and it's fine.
Couldn't break the license. Tryed deleting and changing the text file but this prevented skatter to work.
caecarvalho
Postby Pixero » Tue Apr 14, 2015 1:52 pm
I would like to have the option to use center of base as insertion point.
Maybe even a setting to raise/lower the component insertion point.
Pixero
Postby jiminy-billy-bob » Tue Apr 14, 2015 1:57 pm
Pixero wrote:I would like to have the option to use center of base as insertion point.
You already can do these things.
Click on the scattered object in the list, this will display its properties and you'll be able to select "Insertion Point : Center" (which is acutally base center)
To lower it, enable "Translation" and put the same value in Z Min and Max.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Pixero » Tue Apr 14, 2015 3:23 pm
Ok, but it doesn't seem to work for me.
I have these (badly made) proxies with the axis in the center but even if I click use center (base center you said it was) they appear half way through the ground. In SU view they look OK but in Thea it doesn't.
Pixero
Postby jiminy-billy-bob » Tue Apr 14, 2015 3:26 pm
Pixero wrote:In SU view they look OK but in Thea it doesn't.
Oh? Then it's probably a Thea issue.
Do you have this issue with every component in every file?
If not, could you provide the problematic file?
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Pixero » Wed Apr 15, 2015 7:18 am
After shutting down SU and restarting. Not sure why but now center works. :thumb:
Pixero
Postby JQL » Sun Apr 19, 2015 12:53 pm
Just tested the licencing system too and it seems to be working fine. Win7
JQL
Premium Member
Premium Member
Postby NigeC » Wed Apr 29, 2015 12:39 pm
Seeing as Tomasz hasn't updated yet I'm using this one.. I can't get it to activate, no folder is created in C:\programdata.....
If I enter the above serial nothing appears to happen and no errors in the Ruby console
I'm using 2015 on Win7 64.. uac is off, tried as an Admin
Maybe its because I've not used previous versions? the dialog displays ok but obviously its not doing anything other than the Pro nag dialog
edit 0.10 activated fine
“It’s only impossible if you stop and think about it!”
NigeC
Postby jiminy-billy-bob » Wed Apr 29, 2015 12:44 pm
Please try Alpha 0.0.10 anyway, just for the licensing part.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby NigeC » Wed Apr 29, 2015 12:45 pm
yes I just tried and it did activate fine, thanks :thumb:
NigeC
Return to Skatter
