Need help punching pattern into cylindrical object
Get 3D Printing support, tips and tricks for SketchUp
Moderators: d12dozr, dukejazz
Postby maclee » Mon Oct 23, 2017 9:11 pm
Hi there! I could really use some guidance. I am very new to Sketchup. I am trying to "punch" the flower of life pattern into a 3mm thick cylinder shape. See attached images for details.
I can recreate the 3d flower shape in Sketchup but then can't figure out how to push it into all the sides towards the centre.
I also tried using the draw on surface tool to draw my own "petals" to punch out. I can get it to work however I have to draw each one separate as I can't copy and paste onto the face and it is difficult to reproduce the exact pattern every time.
Can anybody offer suggestions on how to pull this off?
Thanks in advance for any help!
Lee
maclee
Re: Need help punching pattern into cylindrical object
Postby kimi kimi » Mon Oct 23, 2017 10:06 pm
Reminds me of math problems in school. Modeling is easy, but you need to have a strategy for this. Which I don't have at the moment :D
Cylindrical part on top is easy, just make a cylinder, turn on hidden geometry, make one vertical stripe with these (), then rotate around center of that cylinder (press CTRL to copy while rotating). But for the bottom part which is spherical, that's tough, I don't have an answer for that now.
Maybe download some geodesic dome (that's built from triangles) and try to apply the pattern inside those triangles or on edges... Do that first and then do the top cylindrical part.
Don't give it thickness right away, use Joint Push Pull to extrude it later.
kimi kimi
Premium Member
Premium Member
Postby maclee » Mon Oct 23, 2017 10:44 pm
kimi kimi wrote:Maybe download some geodesic dome (that's built from triangles) and try to apply the pattern inside those triangles or on edges... Do that first and then do the top cylindrical part.
Thanks for your reply kimi kimi. I will give geodesic a try. I may have to use a different program to achieve this not sure yet!
Obstacles do not block the path, they are the path.
maclee
Postby pbacot » Tue Oct 24, 2017 12:56 am
it has to be 3d pattern? , Cutouts? I am not sure how best to do the deformation (Flowify plugin? Shapebender?), but I think there needs to be a unique way this pattern fits, based on the size and for it to work it would be symmetrical. So I would, if it were me.... decide how I wanted the pattern to fit first of all, then work on a section that can be mirrored and duplicated. It may even seem to be half of pattern, if you know what I mean, so you are only working on a small slice that is repeatable by mirroring and rotating.
Depending on the scale, you'll be adding a lot of smaller detail, so probably making sure the object is large enough before you work on it will help SU which cannot make tiny faces and will help you be able to "manually" fix things as you go. You can scale it up then down to the right size in the end to print.
Top SketchUcator
Postby maclee » Tue Oct 24, 2017 1:22 am
Oh I see what you mean, like create a linear rounded section that has all the elements of the pattern and then copy that via rotation until it forms a circle. Great idea! Now lets see if I can pull it off! lol
The actual piece has a circumference of 22cm on the bottom and 60 cm on the top, so would you suggest that I start larger than that and then scale down or is that a reasonable size for small faces?
Thanks again for the suggestion!
maclee
Postby pbacot » Tue Oct 24, 2017 3:37 am
that might be reasonable, while keeping the model as clean and simple as possible. You can make a component of the section--also it would need to start as a full shape to get it right and you'd need to keep it geometrically correct so it aligns perfectly. With components you can have all the identical parts in the model and see how they work together as you go...I see some people doing this sort of work sometimes use larger sections sometimes smaller to be able to model consistent with the overall shape.
Top SketchUcator
Postby maclee » Wed Oct 25, 2017 5:38 pm
pbacot wrote:it has to be 3d pattern? , Cutouts? I am not sure how best to do the deformation (Flowify plugin? Shapebender?), but I think there needs to be a unique way this pattern fits, based on the size and for it to work it would be symmetrical. So I would, if it were me.... decide how I wanted the pattern to fit first of all, then work on a section that can be mirrored and duplicated. It may even seem to be half of pattern, if you know what I mean, so you are only working on a small slice that is repeatable by mirroring and rotating.
Okay so I have reached another wall. I had it all figured out in my head but I can't seem to make it work. I have created the pattern so that I can drape it over the curved edge (I have a square in this picture just to test it out). Then I was going to copy the curved surface to form a circle. The problem I am having is the drape won't work. I watched numerous videos and did exactly what you are supposed to but nothing seems to work. The drape function just doesn't work for me. What am I doing wrong? Does anybody have any advice to get this pattern to drape on the face? I must be missing something important.
Attached is an image of what I am trying to do and if you want to see for yourself here is the file: https://www.dropbox.com/s/vm3rrv9vit12p ... 3.skp?dl=0
I also tried draping from above, as a group and as a component, still nothing works...
Thanks for any help!
Lee
maclee
Postby boofredlay » Wed Oct 25, 2017 8:24 pm
This one stumped me but I think I figured out one way to do it. Here is an image of the finished object. I will try to post up a how to here soon...
3
boofredlay
Global Moderator
Postby maclee » Wed Oct 25, 2017 8:26 pm
boofredlay wrote:This one stumped me but I think I figured out one way to do it. Here is an image of the finished object. I will try to post up a how to here soon...
OMG! That is IT! You are amazing. I am still struggling with this 3 days in... lol
Can't wait to see how you did it!
Thanks so much!
Lee :bounce: :shock: :enlight: :D
maclee
Postby pbacot » Wed Oct 25, 2017 9:16 pm
Nice!
Top SketchUcator
Postby boofredlay » Wed Oct 25, 2017 9:56 pm
Here is the tutorial on Youtube: https://youtu.be/sQJoDYOCM0M
This is one way to do it. I am sure there are probably others.
Here are the plugins if you need them.
Joint Push Pull Interactive:
https://sketchucation.com/plugin/715-jointpushpull
Mirror:
https://sketchucation.com/plugin/762-mirror
4
boofredlay
Global Moderator
Postby maclee » Wed Oct 25, 2017 10:28 pm
boofredlay wrote:Here is the tutorial on Youtube: https://youtu.be/sQJoDYOCM0M
Mirror:
Wow boofredlay, that is incredible. I will give it a try although I think I have to watch your video a few times! lol Thank you so much for taking the time to do this. I really helped seeing such a Pro tackle this concept that I have been thinking about for ages! Finally being so close is great! Now lets see if I can pull it off... lol
Thanks again and great work!
maclee
Postby boofredlay » Wed Oct 25, 2017 10:47 pm
Happy to help. Good luck.
boofredlay
Global Moderator
Postby JQL » Wed Oct 25, 2017 11:34 pm
The pattern isn't right but it was a 15 minute doodle.
Using a single plugin: shape bender. Some kind of steped tutorial inside Skp.
Shape Bender.skp
3
JQL
Premium Member
Premium Member
Postby maclee » Thu Oct 26, 2017 12:01 am
JQL wrote:The pattern isn't right but it was a 15 minute doodle.
Shape Bender.skp
Oh wow JQL another great idea! I tried shape bender originally but was going about it all wrong, I had created a kind of flattened pattern of it and then I tried to roll it up along the edge of the circumference, but that was a disaster as I couldn't get the pattern right. I even tried "unwrapping" the simple model to get the flattened object thinking that I could flatten it, punch the pattern in and then wrap it up again, but I couldn't get that plugin to work, it kept unwinding it for some reason instead of unwrapping it, so I gave up! lol
This is a very clever way of using the shape bender and then tapering that edge on the bottom, very smart! And very helpful also to share the .skp file. Thanks so much! Great to see the starting point with the tile.
This forum is GREAT! I was just about ready to give up...
Lee :)
maclee
Postby JQL » Thu Oct 26, 2017 12:05 am
Lee :)
Please don't... Stick around until the point you will be able to help others as others helped you.
The cycle must not stop :)
JQL
Premium Member
Premium Member
Postby maclee » Thu Oct 26, 2017 12:13 am
JQL wrote:
Lee :)
haha, right! I have a feeling I will be posting quite often... Sketchup is such a fun program to learn and even more so when you have people helping you when you get stuck!
maclee
Postby boofredlay » Thu Oct 26, 2017 2:48 pm
Using a single plugin: shape bender...
JQL, how did you go from the step on the right to the one on the left?
Also, your final shape has quite a bit of overlap. I assume this is not ideal for a 3d print. Curious.
boofredlay
Global Moderator
Postby JQL » Thu Oct 26, 2017 4:57 pm
I used shape bender using the arc of rhe pie.
In the end there's cleaning up to do to reach the last step as shape bender wasn't able to compress the bottom center part to an edge.
JQL
Premium Member
Premium Member
Postby boofredlay » Thu Oct 26, 2017 5:04 pm
:thumb: Cheers.
boofredlay
Global Moderator
Postby ntxdave » Thu Oct 26, 2017 5:27 pm
JQL wrote:I used shape bender using the arc of rhe pie.
I have used Shape Bender many times but not sure I fully get this part. Fully comprehend doing the curve to obtain the shape of the vessel but do not fully comprehend how to perform the taper.
ntxdave
Postby maclee » Thu Oct 26, 2017 6:42 pm
When I bend my shape many of my petal cutouts get messed up, do you think it could be because I am working in real scale and I should start larger and then shrink it down? Yours stayed so perfect!
My real scale is bottom c=22cm top c=64cm height 24cm
maclee
Postby JQL » Thu Oct 26, 2017 7:33 pm
maclee wrote:When I bend my shape many of my petal cutouts get messed up, do you think it could be because I am working in real scale and I should start larger and then shrink it down? Yours stayed so perfect!
That should be the issue. Try scaling it up by 10 and then 10 again until Shape Bender doesn't cause issues.
JQL
Premium Member
Premium Member
Postby JQL » Thu Oct 26, 2017 8:52 pm
The trick with shape bender is that the edge that is parallel with the component, must be in the vertical projection of the component's X axis. Then you can control the final result precisely like this (click the gif):
JQL
Premium Member
Premium Member
Postby maclee » Thu Oct 26, 2017 9:23 pm
Using a single plugin: shape bender...[/quote]
It looks like perhaps he scaled it to match the size of the triangle?
maclee
Postby JQL » Thu Oct 26, 2017 10:01 pm
Check the following gif.
JQL
Premium Member
Premium Member
Postby maclee » Thu Oct 26, 2017 10:19 pm
JQL wrote:Check the following gif.
I was just struggling with that part. Great how you used the bend tool again to create that triangular shape at the end. Lets see if I can pull it off now... lol
maclee
Postby boofredlay » Thu Oct 26, 2017 10:28 pm
This is great JQL however when you have to trim the edges because of the overlap the original pattern is destroyed. I have been struggling with the right angle to make the shape "wedge" to a point so no trimming is necessary.
boofredlay
Global Moderator
Postby maclee » Thu Oct 26, 2017 10:50 pm
What if you trim the shape at the beginning with the original strip. Starting the trim at the same spot the shape starts to bend and then ending it at the width for the bottom circle ratio. It would possibly give a bit more control over the scaling of the pattern but the angle would only work if it was a uniform arc. Is this right?
maclee
Postby JQL » Thu Oct 26, 2017 11:03 pm
Share your model at the same stage boofredlay, I'm sure there is a solution.
JQL
Premium Member
Premium Member
Next
Return to SketchUp for 3D Printing
