by Anton_S » Fri Aug 08, 2014 10:17 pm
Anton_S
- PluginStore Author
- Name: Anton
- Operating system: Windows
- SketchUp version: 2018
- License type: Pro
- SketchUp use: hobby
- Level of SketchUp: Advanced
by solo » Fri Aug 08, 2014 10:35 pm
Is it available in SCF plugin store?
solo
- Global Moderator
- Name: solo
- SketchUp version: 2017
- License type: Pro
- SketchUp use: other
by Anton_S » Fri Aug 08, 2014 10:39 pm
No, not yet in the pluging store. I want to make coplanar faces to merge properly, or at least give it to ThomThom for his cleanup collection. I bet he will know how to complete it. Lets see what he has to say.
Anton_S
- Name: Anton
- License type: Pro
by CadFather » Sat Aug 09, 2014 12:03 pm
Thank you Anton!
CadFather
- Name: CadFather
- SketchUp version: 2014
- License type: Pro
- SketchUp use: landscape architecture
by baz » Sat Aug 09, 2014 12:11 pm
Cheers Anton, this will be uber useful for those dratted entities which wont 'fix'.
I am both an early bird and a night owl, I am some form of permanently energized dragon.
baz
- Name: baz
- SketchUp version: 2019
- License type: Pro
by llamamarc » Wed Nov 26, 2014 4:46 pm
I installed this plugin using the Sketchucation auto install on my Sketchup 8 program and when I restarted Sketchup it gave me a Bug Splat error that I cannot recover from. To make it worse, The error doesn't allow the software to send the report. Anyone know how to repair this? Is there a Sketchup restore option? or do I just have to uninstall and reinstall everything all over again? Very annoying and it is halting my production.I have the error report but no one to send it to.
llamamarc
- Name: Marcos Pajuelo
- SketchUp version: pre-2013
- License type: Free/Make
- SketchUp use: engineering and mechanical design
by Anton_S » Wed Nov 26, 2014 6:28 pm
Maybe it has nothing to do with the plugin. I will check it out on my SU8.
Meantime, all SU8 plugins are in C:\Propgram files (x86)\Google\Google SketchUp 8\Plugins\
Once you get there, try deleting this plugin, and restart SU. If the crash still occurs, try erasing the whole god damn plugins folder and see what happens.
Anton_S
- Name: Anton
- License type: Pro
by KMAM » Tue Apr 17, 2018 8:36 pm
I keep having it remove glass out of my windows... Otherwise I am very happy with it. Any way to keep this from happening?
KMAM
- Name: KM
- License type: Pro
by juju » Tue Apr 17, 2018 8:53 pm
KMAM wrote:I keep having it remove glass out of my windows... Otherwise I am very happy with it. Any way to keep this from happening?
How do you model your window glass?
juju
- Premium Member
- Name: Juju
- License type: Pro
- SketchUp use: architecture
by KMAM » Wed Apr 18, 2018 2:23 pm
.25 between two faces that are both facing out. (if I have more the rendering program does not have much transparency)
KMAM
- Name: KM
- License type: Pro
by GD3Design » Thu Jun 17, 2021 7:16 pm
Hello Anton, I use this plugin so much that I have keyboard shortcut assigned to run it. Problem is that I sometimes accidently run it while nothing is selected....which of course runs FixIt on the whole model. Sometimes no problem, but in very large & detailed models it can be bad news. So my question, is it possible to add a warning dialog box like, 'You are about to FixIt the whole model. Proceed? 'Yes' or 'No'. Or maybe easier, is there a way to disable running on the whole model, as some plugins won't run unless you have something selected? Maybe snippet of code I can copy/paste into the rb file?
Thank you, GD
GD3Design
- Name: Greg Davis
- License type: Pro
by rv1974 » Fri Jun 18, 2021 7:23 am
I wouldn't touch a plugin with such defect. Fredo and TT have alternatives (though separated)
rv1974
- Name: rv1974
- License type: Pro
by mizar » Mon Dec 06, 2021 2:53 pm
Molte grazie Anton
mizar
- Name: guido
- Robot
Return to Plugins
