[Plugin] Centering plugin
Made a quick right-click menu for centering selections. (Version 1.0 Available in the Plugins Store)
The main purpose is centering geometry on a selected Edge or Face.
There are 3 options:
Move to origin Center on origin Center over origin
Each option acts as expected with Groups and Components.
When working with non-grouped geometry, all connected geometry is also selected and moved. However, the single selected Face or Edge is used as the object origin, which means you can center the geometry by face or edge.
Thank you.
That's killer
Where is the plugin?
Here is a similar one. But its old and I don't know if it works with current version of SketchUp.
There is also Chris Fullmer's 'Center on Origin' plugin available at the Extension Warehouse:
https://extensions.sketchup.com/en/content/clf-center-origin
I should note that CLF Center on Origin is missing a 'Center over Origin' option (unfortunately) and only works on Groups / Components — not raw geometry.
Yes, "Center over Origin" is the reason to search for Jim's plugin.
His page in "PluginStore" is empty.(???) -
