[PLUGIN] Voronoi + Conic Curve
Just download the later RBZ version from the PluginStore.
Then install it.
It includes the helper files needed too...
Trying to load out-of-date RB files is a recipe for frustration...
https://sketchucation.com/pluginstore?pln=VoronoiXY -
nice
not getting the download link plss help
Click the "Download" button at the first post of this topic. On the next page click "Download" near the description of the plugin.
Or find in by searching the PluginStore...
The first-post's 'Download' button is a direct link to that entry ! -
Hi All, I am also so dull and can't find your working download (I would like to use this tool on my private Make 2017 and, if possible, on Pro2019). So I´m looking forward to any patient help
Try the Download button in this post:
https://sketchucation.com/forums/viewtopic.php?p=538039#p538039 -
... thanks again TIG your Link worked fine
no puedo intalarlo..me pide el formato *.rbz ...!! ayudaa
It says in the earlier post - PLEASE GET/USE THE LATEST VERSION...
FROM THE PluginStore...
When it is downloaded, then that is in RBZ format.
Dice en la página anterior - POR FAVOR, OBTENGA / UTILICE LA VERSIÓN MÁS RECIENTE...
DESDE EL PluginStore...
Cuando se descarga, entonces está en formato RBZ. -
using voronoi is giving me error 'no guide points in selection; although i have guide point in selection
Post your SKP (save as V6 for a more large audiance)
and look all my videos or images "page 4" -
How do you download this extension
Please make some effort before asking questions, the link is on this very same page just 3 posts above yours.
Nide Plugin! , thank you.
i can t launch these extensions in sketchup and i don t know why
i tried to convrt theme to a .RBZ format but it didn t work
and how can i put them bth in the same extension ? -
and how can i put them bth in the same extension ?What version of SketchUp are you using? You listed a non-existent version in your forum profile.
How did you try to convert them to .rbz files?
hello where i find the link for plug in I cant see the link, would you mind putting the link down below . thank you
@Jaijai22 said in [PLUGIN] Voronoi + Conic Curve:
Or install directly in SketchUp using Sketchucation Tools
