how to use .VISMAT files for Vray for Sketchup
General discussion on V-Ray for SketchUp
Postby Nilsvdc » Wed Feb 03, 2010 3:46 pm
Hi guys!
I recently downloaded a package of interesting .VISMAT material files tu use for Vray for sketchup. I tried to figure out how to use them, but i really don't know how????
Can somebody help me?
Thanks!
Nilsvdc
Re: how to use .VISMAT files for Vray for Sketchup
Postby EarthMover » Wed Feb 03, 2010 4:05 pm
In sketchup, assign a material/color to face and name the material. Open the Vray material editor and find the material you want to replace with the .vismat. Right click on it and choose import material. Browse to and select the .vismat. That's it. Quick and simple once you get the hang of it.
6
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby Nilsvdc » Mon Mar 01, 2010 11:54 pm
Allright, it works... thanks a lot for the help!
Nilsvdc
Postby RUSSELL.CALL » Tue Jun 21, 2011 6:38 pm
Hey there. I just downloaded the materials pack and followed the steps above. The material is displayed in the preview fine and changes in the sketchup model but when I go to render I get an error message. The error heading is "ASGvis" and the message reads, "We have encountered errors while trying to render. Please check the error log for more details."
I know this is a vague message but any help would be greatly appreciated.
It might be helpful to note that I don't have sketchup 8 pro and am currently running the trial of vray but I've had no problems with rendering before this.
Thanks!
RUSSELL.CALL
Postby junior_architect » Thu Aug 04, 2011 12:58 pm
RUSSELL.CALL wrote:Hey there. I just downloaded the materials pack and followed the steps above. The material is displayed in the preview fine and changes in the sketchup model but when I go to render I get an error message. The error heading is "ASGvis" and the message reads, "We have encountered errors while trying to render. Please check the error log for more details."
Thanks!
Hi there i am having the same problem as RUSSELL.CALL please let me know if this issue has been resolved. Thanks.
junior_architect
Postby valerostudio » Thu Aug 04, 2011 9:09 pm
What kind of material is it? Could be an issue using a new material with the old V-ray. I do believe you will need the latest plugin to use some of the newer cooler materials.
valerostudio
Postby junior_architect » Thu Aug 04, 2011 9:58 pm
junior_architect
Postby Scostumatu » Fri Aug 05, 2011 5:45 am
Hi all
it may be because the vismat is calling for a bitmap material associated with the vismat.
From memory, those vismats provided do NOT have the bitmaps included.
You can review the exact error here:
C:\ProgramData\ASGVIS\VfS\vfs_stderr.txt
If you cannot open it (due to the program using it), then make a copy of this file and review it that way!
Hope this helps
S
Scostumatu
Postby junior_architect » Fri Aug 19, 2011 3:20 pm
Thanks will check up on those bitmaps...also i think the problem was in some components downloaded from the sketch up warehouse. Once i deleted these, sketch up was rendering perfectly...(well a little slow but rendering nevertheless).
junior_architect
Postby theverylastofart » Wed Sep 07, 2011 9:21 pm
junior_architect wrote:Thanks will check up on those bitmaps...also i think the problem was in some components downloaded from the sketch up warehouse. Once i deleted these, sketch up was rendering perfectly...(well a little slow but rendering nevertheless).
Hey, just had the same problem with the import of the VISMAT material collection.
when you encounter an error log, just go to - plugins - vray - render - clear the list of materials. and start your process again. sometimes i just search the warehouse for materials added to some furniture and extract it and use it th "colors in model" panel of the materials. safe and works without crashing because the information is always saved in the material editor of vray.
hope it helps
theverylastofart
Postby junior_architect » Sat Sep 10, 2011 11:48 am
Thanks for all your help.
junior_architect
Postby tinoguit » Mon Jan 21, 2013 5:36 am
[img]file:///C:/Users/HP/Desktop/Nouveau%20dossier/Capture.JPG[/img]
tinoguit
Postby Gaieus » Mon Jan 21, 2013 11:00 am
Tino, you cannot insert or link to a file on your computer. You need to upload it as an attachment - see the attachment tab under the post text area you are writing your post.
Postby 10103e » Mon Sep 08, 2014 3:28 pm
Hi all, I just tried to use vismat in rendering, although I can now see the new material in rendering, but in the model , it is still the older material lol
10103e
Postby TedVitale_CG » Tue Sep 30, 2014 1:21 pm
Sorry guys, vray.com is not a Chaos Group website. It is a reseller that we are not directly associated with, and they still have a lot of old (bad) materials available on the site. If you are looking for the V-Ray Material collection you can log in and download it from the materials section of www.chaosgroup.com. You may also be interested in the website www.sketchuptexture.com, they are also not associated with Chaos Group, but it is a very handy resource.
I hope this helps!
Ted Vitale
3D Artist|Trainer
Chaos Group USA
http://www.chaosgroup.com
TedVitale_CG
Vray Support
Vray Support
Postby hvanessen » Mon Jul 18, 2016 8:25 pm
When i import the New vismat materialen my preview is allright, but in the sketchup model everything is Grey. I also can't rotate the texturen.
What is the problem
hvanessen
Postby andybot » Thu Jul 21, 2016 3:02 pm
hvanessen wrote:When i import the New vismat materialen my preview is allright, but in the sketchup model everything is Grey. I also can't rotate the texturen.
What is the problem
That vismat may have a "blend" material in the diffuse layer, which means SU can't access the texture to adjust the positioning in the model. Try changing the diffuse layer to Texbitmap and select the image file for your texture.
If that isn't the problem - maybe you can post a screenshot of your vray material settings.
my blog featuring recent projects
andybot
Premium Member
Premium Member
Postby yaxaku » Wed Aug 10, 2016 12:22 am
I had a similar experience with Andybot. In addition, all my renderings come out dark as if I changed the settings to night.
Please help!
yaxaku
Postby MDG237 » Mon Feb 12, 2018 7:23 am
Hi everyone. I have a similar problem to hvanessen. My vismat materials are grey, but look fine in the preview. It's set to a Textbitmap in the Diffuse layer too. How do I solve this. It does this with all my vismats. Im using Sketchup 2016 and Vray
MDG237
Return to V-Ray
