DC Door Builder - Animated
See attached
NOTE:
Dynamic Components can be USED by ALL SketchUp Users - Free & Pro
Release Log:
V1 2009-08-22 first public release.
V1.1 2009-08-23 (Current Version) user instructions in dialog updated
Users can enter variables in any units eg millimetres, feet and inches etc
Door can be set to any size / angle.
Door opens / closes when clicked.
Set the door open angle eg to 45 degrees. Click Apply
To open and close the door to the angle set, use the magic finger on the dynamic components toolbar.
Turn Layers On / Off as required eg (2d) DoorSwing, Origin etc
To reverse the door position...
Pull the scale handles out until the VCB (Measure Box) reads -1 (pull the door inside out)
Keep the <Ctrl> key pressed while doing this in order to keep the door in its original location (if required). (Scale about Centre).
This is all standard SU - except that only 1 set of Scale Handles can be used (the remainder are hidden).
The Scenes (Pages) shown in the *.skp file eg ISO / Elevation / Plan etc can be used to help Export out the data to 2D CAD (eg Autocad) if Reqd.
Modelled doors can be easily adjusted by changing parameters in the white text boxes shown in the DC dialog box.
Any probs / suggestions / improvements / feedback etc - giz a shout
Enjoy
Howard L'
Keywords: DC Dynamic Component Door Doors Animated Animation On-Click
