New for sketchup 2017 - help Edit mode parametric.rb
Goodmorning everyone
I ask for help to complete EDIT mode
based on parametric.rb scripts
a99 = selected faces array (debug)
mullion: to do
thanksSorry for English lev
require 'sketchup.rb' require 'SOFTDEG_vetrate/parametric.rb' module SOFTDEG_Vetrate class Vetrate < SOFTDEG_Vetrate;;Parametric #original offset by Rick Wilson #Smustard def offset_(face=nil, dist=0) return nil if not face or not face.valid? return nil if (not ((dist.class==Fixnum || dist.class==Float || dist.class==Length) && dist!=0)) pi=Math;;PI verts=face.outer_loop.vertices pts=[] 0.upto(verts.length-1) do |i| vec1=(verts[i].position-verts[i-(verts.length-1)].position).normalize vec2=(verts[i].position-verts[i-1].position).normalize vec3=(vec1+vec2).normalize if vec3.valid? ang=vec1.angle_between(vec2)/2 ang=pi/2 if vec1.parallel?(vec2) vec3.length=dist/Math;;sin(ang) t=Geom;;Transformation.new(vec3) if pts.length > 0 if not (vec2.parallel?(pts.last.vector_to(verts[i].position.transform(t)))) t=Geom;;Transformation.new(vec3.reverse) end#if end#if pts.push(verts[i].position.transform(t)) end#if end#upto face.parent.entities.add_face(pts) if pts[2] end#offset_ # Crea vetro doppio, singolo con spessore (thick_v) 0 oppure senza vetro con spessore (thick_v) negativo def vetro(newFace, width, thick, d_a, thick_v, container) frame = container.add_group group_container = frame.entities if thick_v == 0.mm thick_v=1.mm thick_vv=0.mm end da=d_a+(thick-thick_v)/2 intFace=offset_(newFace,-width) telaio_i = intFace.outer_loop.vertices telaio_i = group_container.add_face(telaio_i) if not telaio_i.normal.z == 1 telaio_i.reverse! end status = telaio_i.material = "vetro_01" status = telaio_i.back_material = "vetro_01" vetro1=telaio_i.pushpull((da+thick_v),true) telaio_i.pushpull(da+(thick_v/2)) @entities.erase_entities(telaio_i.outer_loop.edges,intFace.outer_loop.edges) intFace = offset_(newFace,-width) telaio_i = intFace.outer_loop.vertices telaio_i = group_container.add_face(telaio_i) if not telaio_i.normal.z == 1 telaio_i.reverse! end status = telaio_i.material = "vetro_01" status = telaio_i.back_material = "vetro_01" if not thick_vv == 0.mm vetro2 = telaio_i.pushpull(da,true) telaio_i.pushpull(da+(thick_v/2)) @entities.erase_entities(telaio_i.outer_loop.edges,intFace.outer_loop.edges) else @entities.erase_entities(telaio_i, telaio_i.outer_loop.edges,intFace.outer_loop.edges) end newFace.erase! frame end #def # Crea telaio/anta/cornice mediante dimensioni e sfalsamento in asse e offset dalla faccia di partenza (foro muratura) def anta(newFace1, d_o, d_a, width_a, thick_a, container) frame = container.add_group group_container = frame.entities newFacet = newFace1.outer_loop.vertices newFacet = container.add_face(newFacet) if d_o == 0.mm newFace = newFace1 else newFace = offset_(newFacet,d_o) newFacet.erase! end intFace = offset_(newFace,-width_a) telaio_e = newFace.outer_loop.vertices telaio_e = group_container.add_face(telaio_e) telaio_i = intFace.outer_loop.vertices telaio_i = group_container.add_face(telaio_i) telaio_i.erase! status = telaio_e.material = "legno_01" if not telaio_e.normal.z == 1 telaio_e.reverse! end anta1=telaio_e.pushpull((d_a+thick_a),true) if not telaio_e.normal.z == 1 telaio_e.reverse! end telaio_e.pushpull -d_a if not d_o == 0 @entities.erase_entities(newFace.outer_loop.edges, intFace.outer_loop.edges) else @entities.erase_entities(intFace.outer_loop.edges) newFacet.erase! end frame end #def def create_entities(data, container) # Set values from input data a99 = data["a99"] # faccia di partenza a0 = data["a0"].to_l # Cornice esterna Larghezza a1 = data["a1"].to_l # Telaio infisso Larghezza a11= data["a11"].to_l # Lista rifinitura interna Larghezza a2 = data["a2"].to_l # Spessore Vetro a3 = data["a3"].to_l # Stecche oriz. Larghezza a4 = data["a4"].to_l # Stecche vert. Larghezza a5 = data["a5"].to_int # N Stecche orizzontali a6 = data["a6"].to_int # N Stecche verticali # Remember values for next use @@face = a99 @@width_c = a0 @@width_a = a1 @@lista_w = a11 @@thik_v = a2 @@width_so = a3 @@width_sv = a4 @@ns_o = a5 @@ns_v = a6 # imposta costanti anta_a=20.mm # Sfalsamento anta dal telaio thick_c=70.mm # Spessore Cornice thick_a=70.mm # Spessore Infisso Anta lista_t=10.mm # Spessore lista interna lista_d_a=20.mm # Sfalsamento lista dall'anta # Inizio creazione vetrata model = Sketchup.active_model @entities = model.active_entities sel = model.selection # Definisce i due materiali utilizzati mats=model.materials if mats["legno_01"]==nil legno=mats.add("legno_01") legno.color="Brown" end#if if mats["vetro_01"]==nil vetro=mats.add("vetro_01") vetro.color="Gray" vetro.alpha=0.25 end#if if Sketchup.version_number < 7000000 model.start_operation "Vetrate" else model.start_operation "Vetrate", true end faces = sel.select{|e| e.typename == 'Face'} #if not faces.length > 0 #end model.start_operation("Crea Telaio") faces.each do |face| #crea gruppo della faccia originale tgroup=@entities.add_group tentities=tgroup.entities iface=face.outer_loop.vertices oface=tentities.add_face(iface) #crea telaio esterno newFace0=oface cornice_o=a0 cornice_a=0.mm cornice=anta(newFace0,cornice_o,cornice_a, 2*a0, thick_c, container) #crea lista di finitura interna if a11 > 0 newFace1=oface # ottimizza sfalsamento cornice finitura interna if a0 < lista_d_a lista_d_a=a0/2 end lista_o=lista_d_a+a11 lista=anta(newFace1, lista_o, thick_c, a11, lista_t, container) end #crea anta interna if a1 > 0 newFace2=oface anta_o = 0.mm anta=anta(newFace2,anta_o, anta_a, a1, thick_a, container) else a1=a0 anta_a=0 end #crea vetro newFace3=oface if a2 >= 0.mm vetro=vetro(newFace3, a1, thick_a, anta_a, a2, container) end face.erase! tgroup.erase! end model.commit_operation end #end def def default_parameters # Set starting defaults if !defined? @@width_c # then no previous values input defaults = {"a0" => 40.mm, "a1" => 80.mm, "a11" => 70.mm, "a2" => 30.mm, "a3" => 40.mm, "a4" => 40.mm, "a5" => 0, "a6" => 0 , "a99" => nil } else # Reuse last inputs as defaults defaults = {"a0" => @@width_c, "a1" => @@width_a, "a11" => @@lista_w, "a2" => @@thik_v, "a3" => @@width_so, "a4" => @@width_sv, "a5" => @@ns_o, "a6" => @@ns_v, "a99" => @@face } end # if end # default_parameters def translate_key(key) prompt = key case( key ) when "a0" prompt = " Cornice esterna Larghezza " when "a1" prompt = " Telaio infisso Larghezza " when "a11" prompt = " Lista rifinitura interna Larghezza " when "a2" prompt = " Spessore Vetro " when "a3" prompt = " Stecche oriz. Larghezza " when "a4" prompt = " Stecche vert. Larghezza " when "a5" prompt = " N Stecche orizzontali " when "a6" prompt = " N Stecche verticali " end prompt end end # Class Vetrate #============================================================================= if (not $Vetrate_menu_loaded) ### commands cmd1=UI;;Command.new("SOFTDEG_Vetrate") { Vetrate.new } cmd1.tooltip='Vetrate Irregolari Parametriche - donazione PayPal; tiziano.traini@tin.it' cmd1.status_bar_text='Vetrate Irregolari; Seleziona una faccia ...' cmd1.small_icon=File.join('SOFTDEG_vetrate', 'SOFTDEG_Vetrate_16x16.png') cmd1.large_icon=File.join('SOFTDEG_vetrate', 'SOFTDEG_Vetrate_24x24.png') ### menu=UI.menu("Tools").add_item(cmd1) toolbar=UI;;Toolbar.new('SOFTDEG_Vetrate') toolbar.add_item(cmd1) toolbar.restore if toolbar.get_last_state.abs==1 #TB_VISIBLE/NEVER $Vetrate_menu_loaded = true end end # module SOFTDEG_Vetrate
