rendering_options, "back edges"
Postby daiku » Fri Sep 03, 2010 4:06 pm
How do you dump out the list of rendering options? I'm looking for the parameter for the new "back edges" edge style in SU8. CB.
daiku
PluginStore Author
PluginStore Author
Re: rendering_options, "back edges"
Postby thomthom » Fri Sep 03, 2010 4:09 pm
Sketchup.active_model.rendering_options.each_pair do |k,v|; puts "#{k}=#{v}"; end
BackgroundColor=Color(204, 204, 201, 255)
BandColor=Color( 0, 0, 0, 127)
ConstructionColor=Color( 0, 0, 0, 255)
DepthQueWidth=4
DisplayColorByLayer=false
DisplayDims=true
DisplayFog=false
DisplayInstanceAxes=false
DisplaySketchAxes=true
DisplayText=true
DisplayWatermarks=true
DrawDepthQue=false
DrawGround=false
DrawHidden=false
DrawHorizon=true
DrawLineEnds=true
DrawProfilesOnly=false
DrawSilhouettes=true
DrawUnderground=true
EdgeColorMode=1
EdgeDisplayMode=1
EdgeType=0
ExtendLines=true
FaceBackColor=Color(164, 178, 187, 255)
FaceColorMode=0
FaceFrontColor=Color(255, 255, 255, 255)
FogColor=Color(204, 204, 201, 255)
FogEndDist=-1.0
FogStartDist=-1.0
FogUseBkColor=true
ForegroundColor=Color( 0, 0, 0, 255)
GroundColor=Color(210, 208, 185, 255)
GroundTransparency=50
HideConstructionGeometry=false
HighlightColor=Color( 0, 1, 255, 255)
HorizonColor=Color( 0, 0, 0, 0)
InactiveFade=0.25
InactiveHidden=false
InstanceFade=0.5
InstanceHidden=false
JitterEdges=false
LineEndWidth=7
LineExtension=2
LockedColor=Color(255, 0, 0, 255)
MaterialTransparency=true
ModelTransparency=false
RenderMode=2
SectionActiveColor=Color(255, 135, 0, 255)
SectionCutWidth=3
SectionDefaultCutColor=Color( 0, 0, 0, 255)
SectionInactiveColor=Color(112, 105, 97, 255)
ShowViewName=true
SilhouetteWidth=2
SkyColor=Color(198, 205, 208, 255)
Texture=true
TransparencySort=0
PluginStore Author
PluginStore Author
Postby daiku » Fri Sep 03, 2010 4:44 pm
Thanks. I can't see any differences between when "back edges" is turned on or off. CB.
daiku
PluginStore Author
PluginStore Author
Postby dem » Sat Dec 18, 2010 1:13 am
+1
I`m searching name of rendering option
dem
Postby Dan Rathbun » Sun Dec 19, 2010 12:24 am
daiku wrote:Thanks. I can't see any differences between when "back edges" is turned on or off.
You are correct. I filed a beta bug report, and Simone logged it as internal bug 2916316.
Additional comments, and ideas I posted:
DanRathbun wrote:OK.. I looked at this a bit further, and my conculsion is that...
RenderingOptions[’EdgeDisplayMode’] needs to be updated.
The setting is tied to Edges
Currently the value of the RenderingOptions[’EdgeDisplayMode’] key is 0 when both are turned off.
Toggling Edges ON adds 1 to the value. (BUT.. if BackEdges is ON, and you turn Edges OFF, the value remains at 1.)
We need toggling BackEdges ON to add 2 to the value, so that:
RenderingOptions[’EdgeDisplayMode’] :
0 = both OFF
1 = Edges ON && BackEdges OFF
2 = Edges OFF && BackEdges ON
This may not be used (rendered,) meaning that mode 3 would be enforced, but we should still be able to test for mode setting 2 (the state of checkboxes in the Styles dialog, and the menu item check states.)
3 = both ON
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby dem » Sun Dec 19, 2010 6:45 pm
    thanks, but
    in ruby console
    Code: Select all
    Sketchup.active_model.rendering_options["EdgeDisplayMode"] =
    works only 1 and 2
    Sketchup pro 8.0.3117
    dem
    Postby Dan Rathbun » Sun Dec 19, 2010 9:13 pm
    dem wrote:thanks, but
    in ruby console
    Code: Select all
    works only 1 and 2
    It should only have 0 and 1 values at this time.
    You did not read what I said correctly. I am proposing that values 2 and 3 be added to the API so that we can know the BackEdges setting.
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby dem » Sun Dec 19, 2010 9:51 pm
      Sorry, i mind 0 and 1..
      And how can I add it to API? =)
      ps. my English is not good
      dem
      Postby Dan Rathbun » Mon Dec 20, 2010 6:06 am
      dem wrote:And how can I add it to API?
      You CANNOT.
      Google must do it on the C++ side of the application code.
      That is why I filed the Bug Report, and a number was assigned to it, by the Sketchup Development Team.
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby TBoy » Sat Dec 30, 2017 4:33 pm
        Any updated info for this topic?
        TBoy
        Postby Dan Rathbun » Sat Dec 30, 2017 9:52 pm
        TBoy wrote:Any updated info for this topic?
        YES. (5 years after this thread ...)
        In the SketchUp 2015 release, a new key was added to the RenderingOptions hash:
        The key is: "DrawBackEdges"
        See API documentation:
        http://ruby.sketchup.com/Sketchup/RenderingOptions.html
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Return to Developers' Forum
          Users browsing this forum: No registered users and 9 guests
