Sketchup blender transition
Postby L i am » Sun Jan 28, 2018 1:03 pm
Hi all, am considering learning blender and know there is a seriou learning curve involved . I believe the render engine is very good. Is there others on here who have had the experience of this transition?
Truth is I will always use SU for some things. Have no specific questions but would like to know others experience and insight/perspective :?
Premium Member
Premium Member
Re: Sketchup blender transition
Postby pilou » Sun Jan 28, 2018 3:49 pm
Maybe you can also try some free more easy things like
Bricsys Shape or FormZ Free PCon-Planner... ;)
And a free Real Time Render like SimLab Composer Lite (max 1920 *1080)
Speedy Galerie
Top SketchUcator
Postby solo » Sun Jan 28, 2018 5:06 pm
Blender is powerful it can pretty much do everything.
It requires a commitment to master, I have tried and failed twice, I blame my lack of need and laziness for not succeeding. I am sorry I gave up in the past as it would have been an incredible tool to have.
The problem in my case is I need to keep using a tool to remember it, I started learning Blender until a large project came and it was 3 months until I had the chance to go back and continue and realized I'd forgotten pretty much everything I had previously learned.
Rich O'Brien has aced it, maybe he will jump in with some wise words.
http://www.solos-art.com
I'm better with polys than words
solo
Global Moderator
Postby HornOxx » Sun Jan 28, 2018 5:29 pm
Hi - Chipp Walters has recently launched the thread "SketchUp to Blender observations" here which could get an interesting series in this context
viewtopic.php?f=15&t=69108#p631099
@ Solo - It was the same for me so far :D ;)
never trust a skinny cook
HornOxx
Postby pilou » Sun Jan 28, 2018 7:32 pm
..3 months...I had the chance to go back and continue and realized I'd forgotten pretty much everything I had previously learned.
Only one day of not using it is sufficient for all forgot ! :D
Speedy Galerie
Top SketchUcator
Postby JQL » Sun Jan 28, 2018 7:46 pm
If you get past the odd selection methods, working without SU very clever inference system, the multiple workspaces and a painful UI spread all over the place, you'll be able to acjive greatness. It has everything SU lacks, SU has everything Blender lacks. Opposites
3
JQL
Premium Member
Premium Member
Postby liam887 » Sun Jan 28, 2018 11:37 pm
I had several goes over a few years but no luck. However once I started learning VR and Unreal engine and noticing all the things I could not do in SU and badly needed I gave it another go.
I used Lynda Training to do the 8 hour Blender Essential Training : https://www.lynda.com/Blender-tutorials ... 088-2.html
I then advanced to other tutorials and examples. I think it took around two months to get to grips with it.
VISIT MY ONLINE GALLERY
liam887
Postby Mike Amos » Mon Jan 29, 2018 12:10 pm
A tough nut to crack but mostly due to the busy and confusing UI that just screams "give up hope all ye who enter here". The UI is where Sketchup has a big advantage, Blender with a Sketchup UI and more people might stand a chance. I see some fantastic aircraft for example and multiple render engines available too.
3
Premium Member
Premium Member
Postby L i am » Mon Jan 29, 2018 12:56 pm
Sincerely thanks guys :thumb: :thumb: I did a short course in Blender (Modelling) 12 years back (knowledge now lapsed) and understand the UI is :puke:
Mike is there any talk of anyone developing a plugin for Blender with a Sketchup UI? That would rock!!
ATM (subject to change) am thinking of keeping with SU modelling and exporting to Cycles. Am thinking if I can get my head around cycles, then I can look again at modelling in Blender at a later stage, reducing the parallel learning of blender modelling and rendering and required associated learning curve. Has anyone had experience in skethup to Cycles render or have an opinion on this approach?
Is there a plugin for Skp to Obj as I am using make.
Sorry for all the questions :?
Premium Member
Premium Member
Postby Mike Amos » Mon Jan 29, 2018 1:13 pm
I have seen lots of contradictory suggestions of UI changes but nothing solid, anyone else?
Premium Member
Premium Member
Postby liam887 » Mon Jan 29, 2018 2:41 pm
Mike Amos wrote:I have seen lots of contradictory suggestions of UI changes but nothing solid, anyone else?
No nothing I have heard and I don't expect anything really. Most people start with 3D software such as Blender or Max so although the UI is much more complicated than Sketchup it's just normal for them. I have lots of friends who started on Blender and they don't see it as complicated. The UI has changed slightly over the years, the biggest aspect is the UI navigation, once you have got round that and selecting and editing meshes then it's not too difficult.
The problem is Blender is infinitely more powerful than SKetchup, not only is it a hard surface modeler but it can handle organic modelling, sculpting, nodes, real time physics, animation, rigging and of course rendering. Even after years there are still buttons and menus that I have not even used!
The best thing rather than 'learn' Blender is identify your need's and if you plan to still use Sketchup, how Blender will become part of your workflow. Then it's just a case of learning specific sections.
If you after rendering them that will be at its most basic UI/Interface > Nodes > Cycles.
The only way I got my head around it was I had a project on that Sketchup could not handle (for a car manufacturer who supplied some incredibly large and detailed models) so I was forced to use Blender. I think if you complete the eight hour Bender Essential training a few times you should have wrapped your head around it. I would highly recommend the Lynda course I posted a while back, you can sign up for a month free trial so you don't have to pay, just make sure you have some time to spend in that month so you can make the most of it.
liam887
Postby pilou » Mon Jan 29, 2018 2:55 pm
You have a free Blender for Kitchen without see not more see Blender! ;)
Fluid Designer
(was in 2015 so now rendering is very more speed! ;)
Speedy Galerie
Top SketchUcator
Postby Glenn at home » Mon Jan 29, 2018 8:29 pm
Trying to learn Blender myself. 1st thing I do is switch selection from Right-click to Left-click. ;) I watched a good video last week on making a chest that was not bad at all.
Glenn at home
Return to Corner Bar
