Overlapping objects when copied
Do you happen to know why this happens?
When you copy an object, type "*" and enter a number, the object overlaps.
It worked just fine a few days ago. Why did this happen? Did I do anything wrong?https://www.facebook.com/100003219512290/videos/1866427950141171/?t=8
Overlapping entities when you make an array with Move/Copy, indicates you aren't moving the first copy far enough from the original.
Your Facebook link is bad.
