Hide lines in Photomatch?
I tried Photomatch for the first time and made some faces on an imported photo. My goal is to change the color of an existing area after the face has been made and by accident I found that what works perfectly is to select the area and apply a new color in X-ray mode, then export it to Gimp. The problem is, it also import a heavy black construction line. is there a way to turn this off before export. I tried unchecking "Guides" and "Edges" in "Edge Style", but that didn't work.
Thanks in advance!
Your image is too small and dark to see what it is you're trying to show.
If you are seeing guidelines, Edit>Delete guides will remove them. If it doesn't, it's not a guideline you're seeing. How about uploading the SketchUp file or at least an image that we can see.
They are definitely guidelines. However, I solved the problem by changing to the wireframe option in the Styles menu, select all, then View>Hide and switching back to the default styles. Lines gone.
