Curved text
General discussion related to SketchUp Pro and Make
Curved text
Postby glenn » Fri Nov 09, 2007 12:02 am
I need to add a sign to a retail center I"m designing.
How do I make the text follow a curve?
It's flat on the wall with the letters following an arc?
Is this possible with 3d text?
I thought about doing it in PS then importing png?
Thanks,
Glenn
glenn
glenn
Re: Curved text
Postby mike d » Fri Nov 09, 2007 12:03 am
there is no way to do it within sketchup
thanks
mike d
The grass is always GREENER on the roof.
mike d
Re: Curved text
Postby TIG » Fri Nov 09, 2007 12:03 am
glenn wrote:I need to add a sign to a retail center I'm designing.
Thanks,
Glenn
Make the text as a image (png/jpg) in PS etc, import it as a texture and wrap it around the curved face - there are examples in Help about wine bottle labels etc...
You could make individual 3D letters [as groups] and then place and rotate each one individually about a fixed centre point...
Global Moderator
Re: Curved text
Postby glenn » Fri Nov 09, 2007 12:04 am
Thanks for the quick replies.
If I wasn't clear, the surface is flat, I want the letters to follow a curve/arch.
I made it in PS & import as an image.
Thanks again,
Glenn
glenn
glenn
Re: Curved text
Postby bubbalove » Fri Nov 09, 2007 12:06 am
Make each individual letter a component and then just rotate them to fit the arch. I had to do it on a project myself. Except mine wasn't on a flat wall. But it would still be the same concept. I uploaded a pic to show you.
Edit: Oops, nevermind Tig already said it...
BubbaLove
"Success consists of going from failure to failure without loss of enthusiasm." - Churchill
bubbalove
Re: Curved text
Postby glenn » Fri Nov 09, 2007 12:06 am
I really need to learn how to read....or at least slow down while I"m reading.
I missed the second idea from TIG.
I hadn't thought about that. I'm always lookin' for the easy one click to get what I want
Thanks again,
Glenn
glenn
glenn
Re: Curved text
Postby not registered yet » Fri Nov 09, 2007 12:07 am
If you have Autocad, you could use arc text, explode the text and import into sketchup.
Robert Good
robert_good
not registered yet
Re: Curved text
Postby tomsdesk » Fri Nov 09, 2007 12:07 am
I use CorelDraw for such...fit text to path, explode to curves, export as dxf.
tomsdesk
tomsdesk
Re: Curved text
Postby Cyberdactyl » Fri Nov 09, 2007 12:08 am
robert_good wrote:If you have Autocad, you could use arc text, explode the text and import into sketchup.
Robert Good
http://www.digitalnursery.net
Great idea. Then simply extrude.
Cyberdactyl
Cyberdactyl
Return to SketchUp Pro & Make Discussions
Users browsing this forum: No registered users and 10 guests
