Invalid model
Found a bug in SketchUp? Report it here
Invalid model
Postby rv1974 » Sun Aug 26, 2012 7:05 am
never seen it before (for 10 years):
Reason: Split post off the "Duh thread" as it has nothing to do with any "enlightment" moments
rv1974
Re: Invalid model
Postby Gaieus » Sun Aug 26, 2012 9:17 am
So could you recreate the error message by repeating the steps (which would be needed for any kind of further investigation)?
Re: Invalid model
Postby rv1974 » Sun Aug 26, 2012 10:06 am
Unfortunately I did not saved the problematic state as separate file.
I've made a group of a face contour the copied it upward and tried to extrude the edges within the group with TIG's old good 'extrude edges'.
Then after some freezing this pop-up of death appeared.
rv1974
Re: Invalid model
Postby TIG » Sun Aug 26, 2012 10:28 am
I tried to replicate this without any success.
What exact dimensions were you using?
My EEby... tools are robust and work if the initial objects selected and subsequent input comply with the tool's needs etc, so I can't see what's going wrong.
Dis it occur during picking or during the latter stages - like reversing faces or exploding the extrusion-group ??
If you can't reproduce it then it's probably a one-off glitch within Sketchup itself... :?
Global Moderator
Re: Invalid model
Postby pilou » Sun Aug 26, 2012 10:53 am
It's not the new message for avoid the Splatch screen ?
Speedy Galerie
Top SketchUcator
Re: Invalid model
Postby rv1974 » Sun Aug 26, 2012 11:42 am
TIG wrote:I tried to replicate this without any success.
I used (and undoubtedly will) the oldie called 'extrudelinetool.rb' -one of my favorite tools. Never had problems for years- no complains. Originally I posted this pop-up in the 'Doh!' thread to show the message I've never seen before.
The cause for this glitch (at least I guess so) was some hidden triangular face when I tried to extrude the lines(I saw it after as unhidden in the autosave file).
rv1974
Re: Invalid model
Postby DesertRaven » Sun Aug 26, 2012 9:48 pm
LOL, I had this error just a few days ago, the joke here is they ask you to report the steps leading up to this error.
Well if I had expected this error maybe I would of recorded the steps.
All I can say is this error message occurred after hours of editing a organic shaped building. Last step may have been to save the model? I work allot with solids subtraction and the outer shell tool. So I am sure just before saving I did a subtract operation.
BTW, the best script ever made for solid modeling in SU is the Solid Inspector from TT!!!
This tool should of been in the tool set to begin with, or maybe in consequence they should of provided a detection and fix tool instead of just blunty rejecting solids and leaving one to such the model or object in question for tiny little mistakes.
Also does anyone know how to actually contact Google support? ? ?
simplicity is the ultimate sophistication
DesertRaven
Re: Invalid model
Postby Gaieus » Sun Aug 26, 2012 11:32 pm
The reason they ask for the exact steps (especially if you can reproduce the error) is that this way they can identify the bug (if there is any) which causes it. There is actually a lot going on under the hood and only a few errors generate a popup like this.
DesertRaven wrote:Also does anyone know how to actually contact Google support? ? ?
If it's about the bug issue, here is the trouble shooter:
http://support.google.com/sketchup/bin/ ... page=ts.cs
Re: Invalid model
Postby rv1974 » Mon Aug 27, 2012 4:59 am
DesertRaven wrote:...Last step may have been to save the model?...
+1
the very last step before error was file-save
rv1974
Re: Invalid model
Postby thomthom » Mon Aug 27, 2012 9:57 am
SketchUp isn't part of Google any more. They're now owned by Trimble.
PluginStore Author
PluginStore Author
Re: Invalid model
Postby DesertRaven » Sat Dec 15, 2012 3:45 am
Gaieus wrote:The reason they ask for the exact steps (especially if you can reproduce the error) is that this way they can identify the bug (if there is any) which causes it. There is actually a lot going on under the hood and only a few errors generate a popup like this.
Ha ha all they had to do is produce some errors of their own, most issues are not new but never corrected.
This particular pop up window is completely useless! Just fix what you guys know is wrong and we'll all be good.
DesertRaven
Return to SketchUp Bug Reporting
Users browsing this forum: No registered users and 4 guests
