Layers To List    v1.0
TIG (c) 2015
All rights reserved.
TIG-LayersToList.rb
Installation:
Suitable for SketchUp Versions >= 2014...
The RB file goes in the Plugins folder [restart Sketchup].
Or much easier, no restart required !
Use the Preferences > Extensions > Install button... on the RBZ archive.
Overview:
A tool to write Layers' data to a file :
Layer's by Name and the Layer's Colors RGB values.
Plugins|Extensions > TIG-LayersToList
Makes a file with a line for each Layer Name and Color, in the format:
LayerName:R,G,B
The ":" is the separator between the Layer's Name and its R,G,B values.
The R,G,B Color values are separated by commas, and are integers 0 to 255.
These represent the Red, Green, Blue values - the higher the number the more
of that hue in the Color.
Note that the Layer Color's 'A' alpha-transparency is not accessible in the
Ruby API.
The file is a plain text file of any name - obviously give it something
that is meaningful to you.
Run the tool...
Chose the file-name... by default it is "ModelName_Layers.txt",
in the same folder as the model.
The LayerName:R,G,B data is written to the file.
Layer names are sorted in order, but "Layer0" always comes first.
The file is opened...
Purpose:
This file can be used in another Model in conjunction with the sibling tool
"TIG-LayersFromList".
You can edit the file before importing its data as desired.
1.0 20150531 First issue.
