by resetarionut » Sun Mar 06, 2022 10:06 am
Hi fredo6,
I am also having a problem with LOT, not a big one but the plugin is not loding with sketchup, I have to manualy open it by navigationg to tools>fredo6>LOT>Master Toolbar Manager, or any other menu that forces LOT to start, and my custom toolbars lose placement, the toolbars are reseting to floating toolbars. I have sketchup 2022 on windows 10, everytinh is up to date. It worked before the latest update.
resetarionut
- Name: Ionut Resetar
- Operating system: Windows
- SketchUp version: 2022
- License type: Pro
- SketchUp use: woodworking
- Level of SketchUp: Intermediate
by fredo6 » Fri Mar 11, 2022 11:16 pm
resetarionut wrote:I am also having a problem with LOT, not a big one but the plugin is not loding with sketchup, I have to manualy open it by navigationg to tools>fredo6>LOT>Master Toolbar Manager, or any other menu that forces LOT to start, and my custom toolbars lose placement, the toolbars are reseting to floating toolbars.
Could you update to LibFredo6 v12.7a and check if you see errors displayed in the Ruby console at startup.
- Premium Member
- Name: Fredo6
- License type: Pro
- SketchUp use: interior design
by resetarionut » Sun Mar 27, 2022 12:26 pm
Hi Fredo,
Sorry I didn't answer back but it seams I don't get any emails with replays, I didn't know there is no email notifications ...
I keep all plugins up to date. Right now I have LibFredo6 12.8a the latest. The issue is still present and I have attached what comes up in the console at startup.
If you don't find anything relevant to help me fix this from what I am sending should I try a full reinstall of sketchup and see if that works?
Thank you very much for your time.
resetarionut
- License type: Pro
by aa6 » Tue Apr 05, 2022 8:28 pm
Having similar problem... the plug-in seems to work fine, but I can't get the vignette stripe to display. I can see it with "pop up the vignette stripe" but it comes up as a floating menu and then disappears when I click away.
aa6
- Premium Member
- Name: andy rhodes
by fredo6 » Tue Apr 05, 2022 8:32 pm
aa6 wrote:Having similar problem... the plug-in seems to work fine, but I can't get the vignette stripe to display. I can see it with "pop up the vignette stripe" but it comes up as a floating menu and then disappears when I click away.
Could you open the Ruby Console at startup to see potential errors (just open the Ruby console, quit Sketchup and restart Sketchup).
- Premium Member
- Name: Fredo6
- License type: Pro
by AISmebel » Wed Apr 06, 2022 11:37 am
I really look forward to fixing this error. I have been working with this problem for several months, it greatly interferes when after each launch of SU. When you first need to run Lord (so that the icons appear), and then they need to be put in their places (because after launch they appear in the center of the monitor)  ((
AISmebel
- Name: Иван
- SketchUp version: 2018
- License type: Pro
- Level of SketchUp: Beginner
by aa6 » Wed Apr 06, 2022 5:56 pm
Hi - Thanks for the quick response! I re-started with the ruby console open, but I don't see any errors - although I'm not exactly sure what I'm looking for.
aa6
- Premium Member
- Name: andy rhodes
by rv1974 » Thu Apr 07, 2022 7:28 am
Fredo, is there any technical obstacle to show user's shortcuts in the tool tips and command search?
rv1974
- Name: rv1974
- SketchUp version: 2017
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by digitect » Wed May 11, 2022 4:40 pm
No vignette stripe for me either on SketchUp Pro 2020 on Windows 10, with LOTT v2.0a and LibFredo6 v12.8a.
I can make it temporarily visible via menu Tools > Fredo6 Collection > LOTT > Pop Up but then it disappears the first click anywhere in the SketchUp window. Ruby Console shows no actions or errors.
digitect
- Name: Steve Hall
- SketchUp version: pre-2013
- License type: Pro
by Scozzarella » Wed May 11, 2022 4:55 pm
Sketchup 2022 MAC
the Pie Tool doesn't work if I press the button on Palette of LordofTheToolbars.
Is it a bug?
Scozzarella
- Name: Angelo
- Operating system: Mac
- License type: Pro
by digitect » Wed May 11, 2022 6:05 pm
digitect wrote:No vignette stripe for me...
UPDATE: I position my Windows taskbar at screen top, and found LOTT beneath it. So that default needs to be adjusted. Once I found, and adjusted, several LOTT positioning options from their defaults (sticky to Sketchup window, position in Popup mode, position when cycling), it behaved as expected.
digitect
- Name: Steve Hall
- License type: Pro
by fredo6 » Wed May 11, 2022 6:41 pm
Scozzarella wrote:Sketchup 2022 MAC
Is it a bug?
As far as I now the Pie tool (from Rich O Brien) is not supported on Mac.
- Premium Member
- Name: Fredo6
- License type: Pro
by Dave R » Wed May 11, 2022 8:08 pm
Scozzarella wrote:Sketchup 2022 MAC...
Is it a bug?
No. As Fredo indicated, Pie is Windows only. Screenshot - 5_11_2022 , 2_06_04 PM.png
- Global Moderator
- Name: Dave R
- License type: Pro
by Scozzarella » Thu May 12, 2022 3:46 am
/Users/angeloscozzarella/Desktop/Schermata 2022-05-12 alle 04.42.13.png
Scozzarella
- Name: Angelo
- License type: Pro
by Scozzarella » Thu May 12, 2022 3:47 am
Scozzarella
- Name: Angelo
- License type: Pro
by fredo6 » Thu May 12, 2022 7:55 am
@Scozzarella
What is the problem?
- Premium Member
- Name: Fredo6
- License type: Pro
by Scozzarella » Thu May 12, 2022 8:37 am
fredo6 wrote:@Scozzarella
If I click on the button with tool indicates by my arrow, (Arc Pie Tool) the tool doesn't activate.
Scozzarella
- Name: Angelo
- License type: Pro
by fredo6 » Thu May 12, 2022 9:28 am
Scozzarella wrote:If I click on the button with tool indicates by my arrow, (Arc Pie Tool) the tool doesn't activate.
Strange. On Mac, it works for SU2021, but not for SU2022 Thanks for signaling the problem.
- Premium Member
- Name: Fredo6
- License type: Pro
by Scozzarella » Thu May 12, 2022 9:40 am
you are welcome
Scozzarella
- Name: Angelo
- License type: Pro
by fredo6 » Sat May 14, 2022 8:56 am
NEW RELEASE: LordOfTheToolbars v2.1a - 14 May 22Requirements- LibFredo6: v12.9a or above
- Sketchup version: SU2017 and above
LordOfTheToolbars 2.1a includes - Bug fixing
- Future compatibility
----------------------------------------- Home Page of LordOfTheToolbars for information and Download. Main post of this LordOfTheToolbars thread.
- Premium Member
- Name: Fredo6
- License type: Pro
by Scozzarella » Sat May 14, 2022 2:48 pm
thank you very much
Scozzarella
- Name: Angelo
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Plugins
