Extension Store - latest version
Got an idea to improve SketchUp?
Re: Extension Store v3.0
Postby Gábor » Sat May 02, 2020 10:18 am
Hi Pipinek,
Cold you please post a screenshot of that error message you get?
Sent from my SM-G965F using Tapatalk
Gábor
SketchUcation IT
Postby TIG » Sat May 02, 2020 1:43 pm
This is odd that it relates differently to opening a new model and opening an existing one.
Are you using the same version of SketchUp each time ?
A screenshot of the messages will help us help you through this.
It might not be directly related to this extension.
For example - if the SketchUp error message's list of 'failed' extensions includes SketchUp's own shipped su_... rbe files [usually near the end of the list?], this is indicative of an incorrect installation of SketchUp itself...
[SketchUp copies over these shipped extensions into the user's Plugins folder as it starts up - if there are permission issues this can fail...
In this case do the following...
Whilst logged into Windows as your normal user-account [NOT the system administrator, but if your normal user has some admin-powers that is OK]
Ensure that SketchUp/Layout are closed.
Find the relevant SketchUp installer's exe file - usually in your Downloads folder ?
Select that installer's exe file and right-click > context-menu > "Run as administrator"
When prompted choose "Repair".
When it finishes restart SketchUp and see if that has changed anything... report back...
Installing any complex app in Windows must be done this way.
Doing the installation in any other way can lead to unexpected and unpredictable issues - often around file/folder permissions and saving settings.
So NEVER double-click on an installer's exe file to "Run" it - it is not the same thing as the method outlined above, even if your user-account has so admin-powers...
If this is not the case perhaps a screenshot of the Plugin-Manager's dialog and a screenshot of your Plugins folder would help...
Global Moderator
Postby pipinek » Sat May 02, 2020 5:58 pm
Gábor wrote:Hi Pipinek,
GReetings,
I do thank you for taking your precious time to response to my issue.
I have tested it and I notice not all SU files opens in this way.
I precise - A given file opens directly by double click in Sketchup with e SU error message whilst open by starting a new SU file and then opening it gives no errors.
Attached-please-find the error message.
Sketchup has been installed as admin.
pipinek
Premium Member
Premium Member
Postby TIG » Sat May 02, 2020 6:35 pm
In the error message the only failing extension is TT_materials_renamer[.rb]
So immediately I suspect that you do not have a suitable version of the TT_Lib installed.
TT = thomthom's extensions usually need his Lib installed to function correctly...
Get the Lib here.
https://sketchucation.com/pluginstore?pln=TT_Lib
Download the RBZ and install it, then restart SketchUp to ensure everything is synced properly...
[or if you have the SketchUcation ExtensionStore² installed then you can use its dialog to do this installation automatically, sidestepping the RBZ download...
Report back...
Global Moderator
Postby pipinek » Sat May 02, 2020 9:46 pm
TIG wrote:In the error message the only failing extension is TT_materials_renamer[.rb]
Get the Lib here.
Report back...
Thank you very much TIG.
DOne.
If any I will drop a line here.
See you on the screen.
pipinek
Premium Member
Premium Member
Postby kiwi15 » Tue Jun 30, 2020 12:07 pm
Just want to report back on a small issue that I have with my SketchUcation ExtensionStore 3.1:
I get a message that I should update a plugin* (s4u Connect) that I have bought and installed from the SketchUp Extension Warehouse when I run ExtensionStore. This must be an error, right?
My license info gets screwed up every time that I accidentally update this extension using ExtensionStore 3.1 instead of the place I bought it.
kiwi15
Premium Member
Premium Member
Postby TIG » Tue Jun 30, 2020 2:43 pm
The author of that Extension posted the update 6 days ago - v2.2.9
Its description does not mention it's 'paid', and his 'More Info' link goes off to Facebook - it should go to its SCF page with links off if needed...
First running it asks for a registration/payment - so it's no trial !
I suggest you get in touch with him directly, as adding a seemingly trial version which overwrites an already licensed version is daft !
I note that the PluginStore version does set up a WAREHOUSE=false constant, but how that interacts with the licensing is unclear as the other files are RBE encrypted...
I will also be having a word too...
Global Moderator
Postby mackinlay53 » Thu Dec 24, 2020 5:04 am
B2Pi wrote:I can't find a reference to this within the forum, but I'm unable to get the Sketchucation ExtensionStore (v3.1.5) working within Sketchup 2017 Make under Wine. Attempting to log in gives "Some error occured please contact the administrator at sketcucation.com". The ruby console helpfully displays nothing
I'll grant that it's not the only problem I'm facing right now (I also can't get cutlist to work, but that's later).
Cheers
2020-12-23 I'm having this same problem and it occurs with both v3.1.5 and v4.0.0. I can use the ExtensionStore to "Create" a new login, but I get the same error as you when trying the "Login" button. My Sketchucation credentials work just fine at sketchucation.com in a browser.
It would sure be nice to sort this problem out.
...Patrick
mackinlay53
Postby Dave R » Sun Jan 03, 2021 2:30 am
...Patrick
What version of Sketchup are you using? Please complete your profile.
Global Moderator
Postby TIG » Sun Jan 03, 2021 2:56 pm
@Patrick
You don't "create new login" for the ExtensionStore³...
You just use the name and password set up for your SketchUcation site membership.
Once you have successfully used it with the ExtensionStore³ you should not be prompted again.
The login details used for the SketchUcation main site, its linked PluginStore [on a separate server and sometimes needing a repeat login], and when you first log into the ExtensioStore³ dialog when it opens from the SketchUcation Tools menu item or toolbar, are all the same...
Global Moderator
Postby sarahpolson » Wed Feb 03, 2021 7:27 am
Rich O Brien wrote:Here's v3 of the ExtensionStore....
http://sketchucation.com/pluginstore?pl ... ationTools
More info to follow
Extension storehttps://www.acousticguitarforum.com/is the best
sarahpolson
Postby RoaryDrake » Thu Feb 18, 2021 7:16 pm
Pardon if this has been asked a million times, I'm having a tough time navigating the forums. Is version 2.6 unavailable now? If it available, where can I find it? I only have Sketchup 8. Thank you for your time.
RoaryDrake
Postby Gábor » Fri Mar 05, 2021 2:19 pm
RoaryDrake wrote:Pardon if this has been asked a million times, I'm having a tough time navigating the forums. Is version 2.6 unavailable now? If it available, where can I find it? I only have Sketchup 8. Thank you for your time.
2.6.1 is available from here: https://downloads.sketchucation.com/plu ... v2.6.1.rbz
I hope it helps.
Gábor
SketchUcation IT
Postby B2Pi » Wed Mar 10, 2021 7:53 pm
I couldn't find a forum for Extension Store v 4.0.0, so this seems like the place.
I've been struggling with the ExtensionStore, as it has not been showing the bundles. I presumed that they had been removed sometime, so I uninstalled the extension store, and installed a copy of v3.1.8 that I had on my machine. I still didn't see any bundles.
I had the store open when I noticed the toaster notification of 'settings'. Clicking where the settings button ought to be (getting to the meat of the matter, now), I was able to get to my bundles. But.... the problem with the store is that, for some reason, the icons aren't showing up. For instance, the main page:
Aha! They're there, but what do you do with them?
OK, I figured out what to do with them, but... this is, I think a bug
Win 10/1909, Sketchup 2017 Make
B2Pi
Re: Extension Store - latest version
Postby robertWan » Thu Jul 22, 2021 12:22 pm
TIG, please write. :D Is it possible to Extension Store with SU8?
Probably not, because the last version 261 did not work, and the new one installs with the message "successful", but the plugin is not visible.
Robert
robertWan
Postby TIG » Thu Jul 22, 2021 2:51 pm
The PluginStore part of the forum has been migrated to a new server.
The https path used in the older ExtensionStore/Tools is therefore likely to be deprecated.
I've pinged Gábor to see what's what...
Can't you run v2017 ?
Remember that you can run the PluginStore in a web-browser, download the desired RBZ and install it in v8 [provided it's a later version] using the Preferences install button, or perhaps the archive installer tool in the SketchUcation menu list...
Global Moderator
Postby Hairman » Fri Jul 23, 2021 3:47 pm
Since a few days I can't update or install extensions on extension store3 anymore.
I get the following message every time: "UnZIP error: could not unzip archive".
I already updated the extension store tool via download and direct install via Sketchup.
I cleared Firefox cache.
I restarted SketchUp.
I rebooted my computer.
So far nothing worked.
Does anyone have an answer to this problem?
Hairman
Postby TIG » Fri Jul 23, 2021 4:25 pm
It might be related to the PluginStore getting a new server recently...
Try clearing your web-browser cache [i.e. Internet Explorer, which is currently used within the ExtensionStore³ dialog etc] and then restarting SketchUp.
This should help sync the correct http paths etc.
Report back if it helps, or not...
Global Moderator
Postby Hairman » Fri Jul 23, 2021 5:35 pm
@Tig Tried that, it didn't work..
Hairman
Postby Rich O Brien » Fri Jul 23, 2021 5:43 pm
You need to clear your Microsoft Edge cache. Firefox is not responsible for display of web dialogs in SketchUp.
Rich O Brien
Administrator
Postby RCD » Wed Jul 28, 2021 6:11 pm
Same here. Worked fine a couple weeks ago. Was going to download from 3-D warehouse and get a pop up saying
"The 3D warehouse requires an internet connection. Please connect and try again"
Already cleared everything from all browsers. Restarted, rebooted, cussed, and tried again.
Never changed a thing. Just started doing this.
HELP!!
Ron
RCD
Postby Rich O Brien » Wed Jul 28, 2021 7:55 pm
3D Warehouse has nothing to do with ExtensionStore :?
Rich O Brien
Administrator
Postby RCD » Thu Jul 29, 2021 5:42 pm
Ok, that's fine but the issue is the internet connection not working on either.
RCD
Postby Rich O Brien » Thu Jul 29, 2021 5:51 pm
It sounds like the issue is unrelated to the SketchUcation Tools since you also have issues connecting to the 3Dwarehouse.
If you are on SU 2021 Pro I would recommend utilizing their support system to troubleshoot why you are experiencing issues.
Rich O Brien
Administrator
Postby leminilab » Fri Aug 27, 2021 9:10 am
Hi!
It's been a loooong time since my last post! :o
I'm facing the same Unzip error isssue. I just cleaned Microsoft Edge's cache but no success... :?
Any suggestion?
Nicolas
- "Live every day as if it were your last and then some day you'll be right."
- "ThomThom rules!!!"
leminilab
Premium Member
Premium Member
Postby Rich O Brien » Fri Aug 27, 2021 10:27 am
Are you running v4.1 the latest release of SketchUcation Tools?
Rich O Brien
Administrator
Postby leminilab » Fri Aug 27, 2021 12:43 pm
Rich O Brien wrote:Are you running v4.1 the latest release of SketchUcation Tools?
Yes. I'm facing the same issue on 3 different machines. All of them having a different zipping program installed.
leminilab
Premium Member
Premium Member
Postby Rich O Brien » Fri Aug 27, 2021 2:24 pm
Try a clean install. Delete sketchucation.rb and its folder.
In Edge make sure you are cleaning all time for all options...
Download the latest release and install via Extension Manager.
If you've already done the above what version of SketchUp are you on?
Rich O Brien
Administrator
Postby TIG » Fri Aug 27, 2021 2:42 pm
The SketchUcation toolset [and indeed SketchUp's Extension-Manager itself] uses a separate in-built unzip method, so what you use to ZIP day-to-day is not important.
The error arises when you try to auto-install through ExtensionStore³ ?
This process involves downloading the RBZ behind the scenes and uncompressing its contents into the Plugins folder...
If so can you then try to download an RBZ file from the Extension-Warehouse and use the Extension-Manager to install it manually - does that work ?
If you download an RBZ file from the Extension-Warehouse and use the SketchUcation tool's Archive Installer from its drop-down menu to install it, does it work ?
If you download an RBZ file from the PluginStore and use the SketchUcation tool's Archive Installer from its drop-down menu to install it, does it work ?
If you download an RBZ file from the PluginStore, finally and use the SketchUp Extension-Manager to install it does that work ?
If you try those permutations we might get nearer to guessing what the problem is...
There are some Temp folders/files you could also look at deleting -
e.g. C:\Users\YOURUSERNAME\AppData\Local\Temp\SCF
AppData stuff is hidden by default, but using the path in a Windows Explorer window should take you there...
Alternatively use the Ruby Console in SketchUp to give you the path directly...
SCF::TEMP >>> C:/Users/YOURUSERNAME/AppData/Local/Temp
or
SCF::TEMPDIR >>> C:/Users/YOURUSERNAME/AppData/Local/Temp/SCF
Delete the SCF subfolder and its contents [if any]...
It subfolder will be remade when SketchUp next runs...
It should have suitable permissions, which might have become cross-threaded...
Global Moderator
Postby leminilab » Sat Aug 28, 2021 3:07 pm
Rich O Brien wrote:Try a clean install. Delete sketchucation.rb and its folder.
Hi Rich,
I just followed your instructions but I'm still facing the issue. :?
I'm on SU Pro 2018.
leminilab
Premium Member
Premium Member
PreviousNext
Return to SketchUp Feature Requests
