MSPhysics 1.0.3 (16 October 2017)
Postby Anton_S » Thu Mar 20, 2014 12:10 pm
MSPhysics
MSPhysics is a real-time physics simulation extension for SketchUp.
MSPhysics allows doing physics simulation of groups and component instances, where each object can be assigned a specific shape, specific states, density, contact properties, magnet properties, script, and more. These features allow complex interactions between objects and the physics world. The parameters of the physics world, such as gravity, update timestep, and solver model, can too be adjusted.
MSPhysics also allows interconnecting objects with joints (constraints) for establishing mechanical interactions between objects. MSPhysics has 14 joints: Hinge, Motor, Servo, Slider, Piston, UpVector, Spring, Corkscrew, BallAndSocket, Universal, Fixed, CurvySlider, CurvyPiston, and Plane. Each joint can be assigned its specific properties, such as minimum and maximum position/angle limits, as well as controllers for controlling position, angle, speed, linear or angular friction, and other. The controllers themselves can be stimulated with a use of a slider controller, keyboard key(s), joystick, and/or a desired script. This flexibility allows creating and inventing many things, such as vehicles, robots, and instruments.
MSPhysics also comes with a reliable Replay animation tool, which allows recording simulation and exporting to SkIndigo, KerkyThea, or a sequence of images.
In many ways, MSPhysics resembles its predecessor SketchyPhysics. First of all, MSPhysics is not a new version of SketchyPhysics. MSPhsyics is written entirely from scratch, integrating the latest Newton Dynamics Physics SDK and heavily basing on a C++ extension. Both are capable of achieving same things, in one way or the other; however, MSPhysics is significantly faster and goes further, especially with a lot of the features described above. MSPhysics has a by far more advanced and a well documented scripting API, allowing users to write more proficient scripts for their models. Another difference is having advantage over user input. In SketchyPhysics there was a struggle in creating keyboard and mouse controlled games. Whenever simulation would run, there had to be an active control panel window to redirect user input, that is to prevent the interference of SketchUp's keyboard shortcuts. In MSPhysics, however, the control panel is not necessary. MSPhysics utilizes AMS Library, which on the Windows side, allows taking control over user input and switching SketchUp fullscreen. Imagine playing FPS games in SketchUp, in fullscreen mode, without having various keyboard commands taking control over the simulation. All that is possible with MSPhysics.
Huge credit goes to Julio Jerez for writing the Newton Dynamics physics engine; as well as, to those who contributed in making this project a reality.
Aside from the ToDo list, the only part that needs heavy working on is the demonstrations and tutorials.
Useful Links
Compatibility and Requirements
  • Microsoft Windows XP or later / Mac OS X 10.6+
  • SketchUp 6 or later. SU2017 64bit is recommended!
  • AMS_Library 3.5.0+
Download
Refer to the list below for various download links:
If encountering errors with overwriting, remove original AMS Library and MSPhysics versions prior to installing the new ones. Refer to the Uninstallation Instructions section for details.
Refer to the video below for a walk-through guide on downloading and installing MSPhysics:
You can instead, refer to MSPhysics Installation Guide installing, uninstalling, and troubleshooting issues.
Recommended Extensions
  • Shapes loader by István Nagy: Allows loading and resizing box, sphere, cone, cylinder, pyramid, capsule, and torus shapes with a click of a mouse. MSPhysics on its own doesn't come with a shapes adder tool, like SketchyPhysics did. This extension fills in the missing tool.
  • SPGears by jgrundman: Even though this plugin was initially intended for SketchyPhysics, it works just fine with MSPhysics as well. Manually drawing gears is not something that one must do, as in the end result, all geometry making up the gears must be distributed into convex subgroups. That is, for the collision to generate properly, each tooth must represent a separate subgroups/subcomponent. SPGears plugin does just that. It draws gears suitable for the collision generation algorithm.
  • Convexify by Fredo6: Splits groups into convex shapes. For dynamic concave shapes to have proper collision shapes, the geometry making up the concave shape must be split into convex subgroups. Until an automatic internal convex decomposition algorithm is developed, this is the right kind of plugin to rely on. This tool is also suitable for fracture effects.
Installation Instructions
Refer to the steps below to install the plugin:
  1. Download ams_Lib_x.y.z.rbz and MSPhysics_x.y.z.rbz
  2. Open SketchUp
  3. Select (Menu) Window->Preferences
  4. Navigate to Extensions section within the System Preferences dialog.
  5. Click Install Extension... button, select ams_Lib_x.y.z.rbz, and click Open.
  6. Repeat the same step for MSPhysics_x.y.z.rbz
  7. Ensure that both AMS Library and MSPhysics extensions are checked.
Refer to the steps below to uninstall the plugin:
  1. Navigate to your plugins folder:
    For Windows
    • For SU8 and below the plugins folder is located in
      • C:\Program Files (x86)\Google\Google SketchUp #\
    • For SU2013 the plugins folder is located in
      • C:\Program Files (x86)\SketchUp\SketchUp 2013\
    • For SU2014 and later the plugins folder is located in
      • C:\Users\[User Name]\AppData\Roaming\SketchUp\SketchUp 20##\SketchUp\
      • %appdata%\SketchUp\SketchUp 20##\SketchUp\
      • C:\ProgramData\SketchUp\SketchUp 20##\SketchUp\Plugins
    For Mac OS X
      • [YOUR USER NAME]/Library/Application Support/Google SketchUp #/SketchUp/plugins
    • For SU2013 and later the plugins folder is located in
      • > Library > Application Support > SketchUp # > SketchUp > Plugins
  2. Select ams_Lib folder, ams_Lib.rb file, MSPhysics folder, and MSPhysics.rb file and delete them.
Credits
  • Julio Jerez for the NewtonDynamics physics engine.
  • Chris Phillips for ideas from SketchyPhysics.
  • István Nagy (PituPhysics), Faust07, and many others for testing.
44
Anton_S
PluginStore Author
PluginStore Author
Re: MSPhysics Preview
Postby Rich O Brien » Thu Mar 20, 2014 12:37 pm
That looks legendary!
Can you assign different masses?
Do static objects have friction levels etc?
If you need a Private Beta forum setup let me know.
Rich O Brien
Administrator
Postby pilou » Thu Mar 20, 2014 12:40 pm
What is advantage / disadvantage between them ?
Speedy Galerie
Top SketchUcator
Postby mitcorb » Thu Mar 20, 2014 12:42 pm
This is interesting. I was having the same kind of questions as Rich about adjustability. Thanks for posting.
mitcorb
Top SketchUcator
Postby Rich O Brien » Thu Mar 20, 2014 12:43 pm
@Pilou
What are you talking about?
@Tim
Great minds think alike....fools seldom differ
Rich O Brien
Administrator
Postby pilou » Thu Mar 20, 2014 12:57 pm
SketchyPhysics / MSPhysics
Speedy Galerie
Top SketchUcator
Postby tt_su » Thu Mar 20, 2014 2:15 pm
This is a completely new plugin? It's not inherited from SketchyPhysics at all?
tt_su
SketchUp Team
SketchUp Team
Postby Anton_S » Thu Mar 20, 2014 8:31 pm
Rich O Brien wrote:Can you assign different masses?
Modifying mass? :puke:
That's just a tiny little bit of the API. :lol: There are lots of things you will be able to do with the bodies.
I'm nearly done with the Body API! Check out documentation if your interested.
tt_su wrote:This is a completely new plugin? It's not inherited from SketchyPhysics at all?
Yes TT, all from scratch! This plugin uses the latest Newton Dynamics 3.12, while SketchyPhysics used some old version. You've seen how fast the wall is simulated. Try simulating the same wall in SketchyPhysics. It will be like 1 FPS (If not BugSplat).
The aim of writing this plugin is to bring SketchyPhysics back! To be honest, the whole point I joined this forum was to learn Ruby programming, in order to have some skills in fixing SketchyPhysics bugs. As time wen't I did fix a few things here and there, but wasn't satisfied. SP needed some general reconstruction. Starting the project from scratch wasn't a bad idea after all.
There are a few things I need to do before releasing the first version:
  1. Dialog
  2. Joints
  3. Materials
7
Anton_S
PluginStore Author
PluginStore Author
Postby Anton_S » Thu Mar 20, 2014 8:39 pm
Pilou wrote:SketchyPhysics / MSPhysics
I won't share any advantages/disadvantages over SketchyPhysics as it might hurt Chris Phillips's (the author of SketchyPhysics) feelings. SketchyPhysics was his idea in the first place. I wouldn't mind renaming MSPhysics to unofficial SketchyPhysics, but only after I make it compatible with SketchyPhysics...
Anton_S
PluginStore Author
PluginStore Author
Postby Frederik » Thu Mar 20, 2014 8:56 pm
I've never tried using SketchyPhysics (primary because I haven't had the need, but also because I heard it was conflicting with other plugins), but this sure looks interesting... :thumb:
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Postby Krisidious » Fri Mar 21, 2014 12:02 am
Any hopes of using this system to test structural stability of home designs?
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby solo » Fri Mar 21, 2014 1:47 am
:berserk:
This will be crazy awesome, please pick me if you need testers as I would love to play with this. I'll also need to get Tomasz (the author of Thea4SU) alerted so we can get render support ASAP as this will be a game changer.
3
http://www.solos-art.com
solo
Global Moderator
Postby pilou » Fri Mar 21, 2014 2:04 am
Do you know that you have also a Physic engine (Bullet) for Sketchup inside Simfonia ? ;)
(free version is existing)
Speedy Galerie
Top SketchUcator
Postby Anton_S » Fri Mar 21, 2014 3:49 am
Krisidious wrote:Any hopes of using this system to test structural stability of home designs?
You won't be able to see the wood break in half, but you would be able to get the force applied on an object.
solo wrote:This will be crazy awesome, please pick me if you need testers as I would love to play with this.
I'll post a beta version someday.
Pilou wrote:Do you know that you have also a Physic engine (Bullet) for Sketchup inside Simfonia ? ;)
Bullet is a good physics engine, but I prefer using NewtonDynamics physics engine for MSPhysics for variety of reasons. It's a free physics engine, as well.
Anton_S
PluginStore Author
PluginStore Author
Postby Krisidious » Fri Mar 21, 2014 4:17 am
"You won't be able to see the wood break in half, but you would be able to get the force applied on an object."
That sounds great, I'm in it for the data not the visuals...
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby solo » Fri Mar 21, 2014 4:33 am
Someday?
solo
Global Moderator
Postby Anton_S » Fri Mar 21, 2014 7:39 am
solo wrote:Someday?
Maybe in a couple of months.
Anton_S
PluginStore Author
PluginStore Author
Postby Krisidious » Fri Mar 21, 2014 10:06 am
This is the internet... If there's no Beta, it didn't happen.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby cotty » Fri Mar 21, 2014 10:29 am
Anton_S wrote:The aim of writing this plugin is to bring SketchyPhysics back!
Great idea :thumb: :!:
cotty
Top SketchUcator
Postby Anton_S » Fri Mar 21, 2014 11:42 am
Krisidious wrote:This is the internet... If there's no Beta, it didn't happen.
:roll: You know what? I don't care if you think it doesn't exist. :lol: I'm good as long as you're not planning to hack into my PC and steal the files.
Anton_S
PluginStore Author
PluginStore Author
Postby tt_su » Fri Mar 21, 2014 11:49 am
Anton_S wrote:hack into my PC and steal the files.
:idea: :twisted:
tt_su
SketchUp Team
SketchUp Team
Re: MSPhysics 0.1.0 Alpha
Postby Anton_S » Sat Apr 26, 2014 8:50 am
Hello guys,
I posted the first alpha version. There are still a lot of things to be worked on, but I thought it wouldn't be a bad idea to upload updates as I go.
Go to the first post and read all the compatibility and requirements, as this plugin is not user friendly yet.
As far as uploading it to GitHub, it will be in a matter of days.
I haven't yet created joints, and the dialog, but you can test destructing building and such things...
Have a nice day!
Anton_S
PluginStore Author
PluginStore Author
Postby cotty » Sat Apr 26, 2014 9:14 am
Fist test VERY promising! :thumb: :bounce:
cotty
Top SketchUcator
Postby kaas » Sat Apr 26, 2014 10:00 am
Very nice. First test no problems. Considering modelling a pachinko machine...
kaas
Postby tt_su » Sat Apr 26, 2014 10:27 am
Anton_S wrote:As far as uploading it to GitHub, it will be in a matter of days.
:bounce: :ecstatic:
tt_su
SketchUp Team
SketchUp Team
Postby josuapa » Sat Apr 26, 2014 7:51 pm
cotty wrote:Fist test VERY promising! :thumb: :bounce:
It's awesome. I'm testing, but my blocks fall into infinity (the boundary surface drops as well) :? . I do not know how to make a surface to retain them. How I can fix it? Could you stop the simulation and save the drawing? Thank you! :D
josuapa
Postby cotty » Sat Apr 26, 2014 9:31 pm
You need a static mesh (context menu).
cotty
Top SketchUcator
Postby Anton_S » Sat Apr 26, 2014 9:41 pm
josuapa wrote:It's awesome. I'm testing, but my blocks fall into infinity (the boundary surface drops as well) :? . I do not know how to make a surface to retain them. How I can fix it? Could you stop the simulation and save the drawing? Thank you! :D
It states in the status text to use SHIFT key to lift objects.
You can use ESC to quit and Break/Pause button to toggle play.
Anton_S
PluginStore Author
PluginStore Author
Postby josuapa » Sun Apr 27, 2014 1:36 pm
cotty wrote:You need a static mesh (context menu).
Thanks a lot ! It's perfect !!!! :ecstatic:
josuapa
Postby Pixero » Sun Apr 27, 2014 7:13 pm
Can it do soft bodies too?
Pixero
Next
Return to Plugins
Users browsing this forum: FRANKRAB, retfgeg and 16 guests
