[Code] Print the transformation matrix
Postby dacastror » Mon Jun 25, 2012 5:37 am
Hi, I'm trying to print a transformation matrix, I tried the following:
pointdd = Geom::Point3d.new 11,22,33
tdd = Geom::Transformation.new pointdd
a = tdd.to_a
text="-------------------------------------------------------\n"
4.times do |b|
4.times do |e|
if ((e+1)%4==0)
text << a[e*4+b].to_s+"\n"
else
text << a[e*4+b].to_s+" "+" "+" "+" "+" "+" "+" "+" "+" "+" "
text<<"------------------------------------------------------\n"
UI.messagebox( text, MB_MULTILINE)
I wanted to hear suggestions of more elegant ways to do this. (I wrote several times +" " for failure to escrbir several spaces followed here)
thank you for your attention.
Reason: Tagged the thread with [Code]
dacastror
Re: print the transformation matrix
Postby danielbowring » Mon Jun 25, 2012 6:42 am
Code: Select all
def inspect_transformation(t)
    ta = t.to_a
    return (0...4).collect() {|i|
        ta[i*4, 4].join(', ')
    }.join("\n")
Code: Select all
>>> point = Geom::Point3d.new 11,22,33
>>> puts inspect_transformation(tdd)
1.0, 0.0, 0.0, 0.0
0.0, 1.0, 0.0, 0.0
0.0, 0.0, 1.0, 0.0
11.0, 22.0, 33.0, 1.0
Edit: And if you like things to line up:
Code: Select all
def inspect_transformation_adv(t, args={})
    format = "%.#{args[:places] || 3}f"
    ta = t.to_a.map() {|i|
        format%[i]
    maxlength = ta.max() {|i, j| i.length <=> j.length }.length
    ta = ta.map() {|i|
        i.ljust(maxlength)
        ta[i*4, 4].join(args[:separator] || ', ')
    }.join("\n")
Code: Select all
>>> puts inspect_transformation_adv(tdd)
1.000 , 0.000 , 0.000 , 0.000
0.000 , 1.000 , 0.000 , 0.000
0.000 , 0.000 , 1.000 , 0.000
11.000, 22.000, 33.000, 1.000
Edit: although that's not the orientation you use
danielbowring
Postby danielbowring » Mon Jun 25, 2012 7:17 am
Here's one in your format, although you should probably use one of the ones above (More info here)
Code: Select all
        format%[i]
    ta = ta.map() {|i|
        i.ljust(maxlength)
    return (0...4).map() {|i|
        (0...4).map() {|j|
            ta[j*4+i]
        }.join(args[:separator] || ', ')
    }.join("\n")
Code: Select all
1.000 , 0.000 , 0.000 , 11.000
0.000 , 1.000 , 0.000 , 22.000
0.000 , 0.000 , 1.000 , 33.000
0.000 , 0.000 , 0.000 , 1.000
>>> puts inspect_transformation_adv(t, {:separator => ' '})
1.000  0.000  0.000  11.000
0.000  1.000  0.000  22.000
0.000  0.000  1.000  33.000
0.000  0.000  0.000  1.000
danielbowring
Postby thomthom » Mon Jun 25, 2012 8:44 am
Is it to visually inspect the matrix of entities, if so you can use this tool: viewtopic.php?t=44859
PluginStore Author
PluginStore Author
Postby Dan Rathbun » Mon Jun 25, 2012 8:45 am
    Here's my simple brute force method:
    Code: Select all
      def trans_matrix_text( gt )
        return "Not a trnasformation object!" unless gt.is_a?(Geom::Transformation)
        a = gt.to_a
        w = 3  # width
        a.each{|n| s = n.to_s.size; w = s if s>w }
        l = (w*4)+3
        # create a line output format string:
        fmt = "  | %#{w}s %#{w}s %#{w}s %#{w}s |\n"
        text = "\n"
        text << (32.chr*2)<<151.chr<<151.chr<<(32.chr*l)<<151.chr<<151.chr<<"\n"
        text << fmt % [  a[0].to_s,  a[1].to_s,   a[2].to_s,  a[3].to_s ]
        text << fmt % [  a[4].to_s,  a[5].to_s,   a[6].to_s,  a[7].to_s ]
        text << fmt % [  a[8].to_s,  a[9].to_s,  a[10].to_s, a[11].to_s ]
        text << fmt % [ a[12].to_s, a[13].to_s,  a[14].to_s, a[15].to_s ]
        return text
      end # def
      pt = Geom::Point3d.new( 11,22,33 )
      text = trans_matrix_text( Geom::Transformation.new(pt) )
      UI.messagebox( text, MB_MULTILINE, "Tranformation Matrix" )
    I have tweaked my system by copying Consolas font to the font used by dialogs, so I have monospaced text output. (It was easier than tweaking the resources in the executable after each update.)
    :idea:
      I'm not here much anymore. But a PM will fire email notifications.
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Re: [Code] Print the transformation matrix
      Postby dacastror » Tue Jun 26, 2012 4:00 am
      Thanks for responding, I have helped a lot. :D
        me a question arises about the transformations. if I need to apply a transformation to an object but not in the principal coordinate axes, but the coordinate axes of a group (rotated) what should I use?
      (sorry for my bad English)
      dacastror
      Postby thomthom » Tue Jun 26, 2012 8:26 am
      You mean, transform an object around its own axis and not world axis?
      PluginStore Author
      PluginStore Author
      Postby dacastror » Wed Jun 27, 2012 5:47 pm
      thomthom wrote:You mean, transform an object around its own axis and not world axis?
      yes, exactly
      dacastror
      Postby thomthom » Wed Jun 27, 2012 8:02 pm
      Create a local transformation and apply with with .transform!( tramsformation ) instead of setting the .transformation matrix manually. Or am I missing something?
      PluginStore Author
      PluginStore Author
      Postby dacastror » Thu Jun 28, 2012 7:15 pm
      thomthom wrote:Create a local transformation and apply with with .transform!( tramsformation ) instead of setting the .transformation matrix manually. Or am I missing something?
      How to create a local transformation? I would like to see some sample piece of code to guide me
      dacastror
      Postby dacastror » Thu Jun 28, 2012 7:37 pm
      I wonder if there is any way to know the orientation of a group with respect to the axis of the world
      dacastror
      Postby TIG » Thu Jun 28, 2012 7:44 pm
      You have the model's axes from X_AXIS etc and ORIGIN.
      Then you have group.transformation.axes or group.transformation.xaxis etc... and group.transformation.origin too...
      So you can find the relative locations [which are points3ds] and angles between axes [which are vector3ds] - see the methods for those types...
      Global Moderator
      Postby thomthom » Thu Jun 28, 2012 8:16 pm
      Code: Select all
      point
      = instance.transformation.origin
      vector
      = instance.transformation.yaxis
      rotation
      = Geom::Transformation.rotation( point, vector, 30.degrees )
      instance.transform!( rotation )
      PluginStore Author
      PluginStore Author
      Postby dacastror » Thu Jun 28, 2012 9:11 pm
      thank you very much Thomas and Tig that prompt reply! :D
      I will try to implement your suggestions right now
      dacastror
      Return to Developers' Forum
      Users browsing this forum: No registered users and 14 guests
