[code] Cleanup After execute_script
Postby Jim » Tue May 29, 2012 1:56 pm
This code cleans-up the cruft left behind when using execute_script. (reference thread)
Chris' version: (viewtopic.php?p=274499#p274499)
Code: Select all
function corePurge(){
   coll = document.body.childNodes;
   for(a=0; a < coll.length; a += 1){
      if (coll[a].tagName ===   "SCRIPT" && coll[a].id === ""){
         document.body.removeChild(coll[a]);
                        a -= 1;
My version:
Code: Select all
function purge_script_tags() {
  var b = document.body;
  var last_node = b.lastChild;
  while(last_node.nodeName === "SCRIPT") {
     b.removeChild(last_node);
Jim
Global Moderator
Re: [code] Cleanup After execute_script
Postby thomthom » Tue May 29, 2012 1:59 pm
jQuery version:
$('body script').detach();
PluginStore Author
PluginStore Author
Postby chrisglasier » Wed May 30, 2012 12:49 am
Jim wrote:...
My version:
Code: Select all
This would remove all last scripts including ones not by execute_script - UHMS
With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
chrisglasier
PluginStore Author
PluginStore Author
Postby Dan Rathbun » Wed May 30, 2012 2:20 am
And in Chris' edition.. if a developer wanted to avoid being cleaned up, he need only set an id attribute on the script object.
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Return to Developers' Forum
    Users browsing this forum: No registered users and 12 guests
