[Plugin] Shell
[Plugin] Shell
Postby thomthom » Tue Aug 09, 2011 12:58 pm
Overview
Result of a work in progress test for another plugin I'm working on. It adds thickness to the surface inside selected groups and components.
Where is differs from Joint Push Pull is that it works on selected groups and components only. A group is added inside the group/component which will contain the shell. It generally seem to work faster than JPP, but it's tested far less and might very well break.
Usage
  1. Select groups and/or components.
  2. Activate Shell from the Tools menu.
  3. Enter a thickness in the VCB or pick a distance in the model.
  4. Double-click to commit. (You can also use Return to commit as long as the thickness has not changed.)
BitBucket
The project is available on BitBucket so if anyone wants to add improvements they can join the project and submit their changes.
https://bitbucket.org/thomthom/shell/wiki/Home
Access
Tools > Shell
Requirements
  • SketchUp 8 or newer - ( Other versions untested )
  • TT_Lib2 (v2.5.4)
Download
Footprint
<Sketchup>/Plugins/
tt_shell.rb
6
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] Shell (0.2.0a) — 09 August 2011
Postby Rich O Brien » Tue Aug 09, 2011 1:01 pm
Nom nom nom :thumb:
I never know where I'm headed, just make it up as I go - Box 22:4
User avatar
Rich O Brien
Administrator
Postby thomthom » Tue Aug 09, 2011 1:07 pm
Rich, I think that a 1.6MB cookie image is warrant for a ban...
User avatar
PluginStore Author
PluginStore Author
Postby Rich O Brien » Tue Aug 09, 2011 1:11 pm
OK, I'll ban you later :thumb:
User avatar
Rich O Brien
Administrator
Postby thomthom » Tue Aug 09, 2011 1:14 pm
I expect a cookie in 1:1 scale to that photo in my mail
User avatar
PluginStore Author
PluginStore Author
Postby EarthMover » Tue Aug 09, 2011 2:13 pm
Looks interesting. Thanks Thom! :thumb:
Content Creator at Skapeup
User avatar
EarthMover
Premium Member
Premium Member
Postby utiler » Tue Aug 09, 2011 2:29 pm
You're :berserk: da bomb, Thom!!!!
Have been feeling for your countrymen of late, mate.... :thumb:
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
Postby driven » Tue Aug 09, 2011 3:15 pm
hi Thomas,
would it be ok to change the menu name to 'tt_shell' as it needs to be unique to use a mac system shortcut key and Jim's simple shell uses 'shell' in the SU menu already...
it also turned off all my other toolbars [except 'booleen helper' and SU ones] when I first loaded/ran it.
never had that happen before...
I'll do some testing tonight.
driven
PluginStore Author
PluginStore Author
Postby thomthom » Tue Aug 09, 2011 3:20 pm
driven wrote:would it be ok to change the menu name to 'tt_shell' as it needs to be unique to use a mac system shortcut key and Jim's simple shell uses 'shell' in the SU menu already...
You can edit line 40 to change the menu name.
driven wrote:it also turned off all my other toolbars [except 'booleen helper' and SU ones] when I first loaded/ran it.
:shock:
There is nothing in the plugin's code that modifies other toolbars. It doesn't even add one itself.
Did it cause any errors when you loaded the first time?
User avatar
PluginStore Author
PluginStore Author
Postby driven » Tue Aug 09, 2011 8:05 pm
yes,
it failed on one particular group and generated error messages, so I'd make something less something less complex, but I noticed all my toolbars had gone.
I turned the same ones back on restarted SU, used tt_shell again and they were fine...
I get non planar faces errors on things that JPP works on.
I'll have a proper look later
driven
PluginStore Author
PluginStore Author
Postby thomthom » Tue Aug 09, 2011 8:32 pm
Can you give me a sample model?
User avatar
PluginStore Author
PluginStore Author
Postby driven » Tue Aug 09, 2011 9:40 pm
hi thomas,
here's something similar that fails tt_skin, but works for JPP.
the lavender one is jpp'd.
Also, the disappearing toolbars are from TIG's new DAE exporter, which uses
Sketchup.send_action('terminate:')
which 'disappears' the toolbars and was the last thing that I had used before I installed this.
tt_skin_test.skp
driven
PluginStore Author
PluginStore Author
Postby thomthom » Tue Aug 09, 2011 9:47 pm
Cheers for the model!
User avatar
PluginStore Author
PluginStore Author
Postby Stinkie » Tue Aug 09, 2011 10:37 pm
Rich O'Brien wrote:OK, I'll ban you later :thumb:
:lol:
Thanks, Thomas!
User avatar
Stinkie
Postby nomeradona » Thu Aug 25, 2011 6:11 pm
this is the one im waiting for. I requested for this before but many keep on pointing joint push pull. thanks thomas..
nomeradona
Postby jorge2011 » Tue Nov 08, 2011 2:54 am
Hi thom, This plugin generates a small error, you can fix that
Error: #<ArgumentError: Points are not planar>
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:370:in `add_face'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:370:in `shell'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:362:in `each'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:362:in `shell'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:321:in `offset_mesh'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:319:in `each'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:319:in `offset_mesh'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:173:in `onReturn'
C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:420
jorge2011
Postby jeff hammond » Tue Nov 08, 2011 3:05 am
wow :shock:
i missed this one..
gonna test it a little later tonight.
thanks thom
User avatar
Global Moderator
Postby thomthom » Tue Nov 08, 2011 8:12 am
jorge2011 wrote:Hi thom, This plugin generates a small error, you can fix that
Ah, yea. There are bugs in this plugin. Hence the Alpha status of the version number. Though I've not had any time to work on it recently.
User avatar
PluginStore Author
PluginStore Author
Postby robert111 » Thu Nov 10, 2011 1:36 pm
mr thomthom
when i make group for this form , i and i use shell plugin , i have this stroange message
robert111
Postby thomthom » Thu Nov 10, 2011 2:08 pm
That error message is not something I've put into Shell. I have no idea where it's coming from. Exactly what is the steps you do to produce that? (Can you also share the model along with the steps?)
User avatar
PluginStore Author
PluginStore Author
Postby j_forrester » Thu Nov 10, 2011 6:33 pm
Is it possible to shell but keep the return from the original geometry. I have tried with JPP too but seems to fall down when you try it with and opening with single extruded returns.
Many thanks
j_forrester
Postby thomthom » Thu Nov 10, 2011 7:11 pm
j_forrester wrote:Is it possible to shell but keep the return from the original geometry.
The generated geometry is created in a separate group - if that is what you mean..?
User avatar
PluginStore Author
PluginStore Author
Postby robert111 » Thu Nov 10, 2011 7:48 pm
i post my file and vedio for this bug
robert111
Postby jeff hammond » Thu Nov 10, 2011 8:13 pm
robert111 wrote:i post my file and vedio for this bug
4.6MB for that .skp :shock:
one word:
PURGE :D
model info -> statistics -> purge unused.
gets it down to around 150kb
User avatar
Global Moderator
Postby TIG » Thu Nov 10, 2011 9:39 pm
Your SKP will shrink to almost nothing IF you use Model Info > Purge Unused...
Then there's no need to zip/rar it and others will be more willing to look at it!
You don't appear to understand the idea of what makes a 'solid'.
An 8 sided box is a 'solid' - all edges have 2 faces - no more, no less.
Your group group has only 4 faces and several edges with only one face... so it's not a 'solid'.
Select two groups in turn and see what the Entity Info dialog says... make one as a 6 sided box [it says it's 'Solid'] and yours will not say it's 'solid' !
Therefore you can't do 'solid' operations on your group - it's not a 'solid'!
User avatar
Global Moderator
Postby thomthom » Thu Nov 10, 2011 10:37 pm
... I'm confused ... you're getting the error when trying to use Solids Tools?
Shell doesn't require solids...
Can you explain step by step what you are doing? (What you click on etc.) Also, what are you trying to accomplish.
User avatar
PluginStore Author
PluginStore Author
Postby robert111 » Fri Nov 11, 2011 12:46 am
i make box and i deleted 02 faces and i have group it
and after i click in this box and i click after shell plugin
i have make video for my file can you see it
the file video is shell bug.rar
robert111
Postby TIG » Fri Nov 11, 2011 10:07 am
Robert
As I tried to explain...
Shell and similar only only work if the group is a 'solid'.
An 6 sided box with no 'holes' is a 'solid'.
If you delete edges and/or faces then it is no longer a 'solid'.
The simple definition of a 'solid' group [or component] is that every edge in it has 2 faces attached to itself - but no more and no less...
User avatar
Global Moderator
Postby thomthom » Fri Nov 11, 2011 10:15 am
TIG wrote:Shell and similar only only work if the group is a 'solid'.
No...
thomthom wrote:Shell doesn't require solids...
I will have a look at the sample video and see if I can understand what this whole is about.
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Fri Nov 11, 2011 10:24 am
Ah!
Now I understand what this all is about!
You're trying to use SketchUp Solid Tools's "Outer Shell" command - instead of "Shell" which is this plugin. I can see how you got confused.
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: clin94, faust07 and 14 guests
