[ Code ] !autoload.rb loads "!_autoload" folders
If you find this useful, please donate:
This is about cleaning up the clutter in the Plugins folder.
This script is meant to be personally modified, especially the paths, for individual tastes.
(The Mac paths are only a poor example on my part.)
You can also see that there are empty sections, where you can add code.
Consider this an Example. Tweak it to your own hearts desire.
- Code: Select all
# File: !autoload.rb
# Prepared by: Dan Rathbun
#{ Versions:
# 1.0.0 : 2011-08-09
# 1.1.0 : 2011-08-09
# 2.0.0 : 2012-02-19
# ~ Changed order of load for user documents plugin paths.
# Version specific path now takes precedence over Common path.
# ~ Made sure the $LOAD_PATH array is uniqued.
# ~ Show Mac paths with whitespace filled with '_' character, for making
# running shell scripts easier.
# ~ Updated Notes section.
# ~ All document header sections now expand and collapse (in Notepad++.)
# 3.0.0 : 2012-09-28
# ~ Added begin .. rescue block to prevent script loading loop from
# short-circuiting when an error occurs in a file.
#{ WARRANTY / DISCLAIMER:
# THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
# IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
# License / Terms of Use:
# Public Domain
#{ NOTES:
# (1) Place this configuration script in the Sketchup "Plugins" folder.
# Create the verdir and comdir directories manually, if you wish to use
# these paths, then edit the verdir and comdir paths to suit your setup.
# * The directories must PRE-EXIST, or they will NOT be added to $LOAD_PATH.
# *** Be sure to save this file as "UTF-8 without BOM" / "ANSI as UTF-8" if
# your directory paths conatain any UTF-8 characters. Also recommend
# that you set end of Line characters to UNIX.
# (2) You can now move any scriptlets out of the Plugins folder, and into
# a new subfolder (of any of the $LOAD_PATH paths,) named "!_autoload".
# Extension registration scripts can go in "!_autoload" as long as they
# use relative paths, and NOT absolute paths.
# (3) True Plugins should go in a subfolder of their own, and even better if
# they are in a subfolder, of the "Author's" folder.
require("langhandler.rb")
require("sketchup.rb")
require("extensions.rb")
require("dynamiccomponents.rb")
#show_ruby_panel() # from "sketchup.rb"
# Push any additional Search paths (that may have a "!_autoload" subfolder,)
# into the $LOAD_PATH array below.
### The directories must PRE-EXIST, or they will NOT be added to $LOAD_PATH.
if RUBY_PLATFORM =~ /(mswin|mingw)/ # MS Windows
# Create HOME environment var if not defined.
# Allows ~ (tilde) path expansion using File.expand_path("~/some/dir/path").
ENV['HOME']=ENV['USERPROFILE'] unless ENV['HOME']
# Example: Windows User Documents Current Version Plugins path:
verdir = File.expand_path("~/My Documents/Google Sketchup/Sketchup #{Sketchup.version.to_i}/Plugins")
$LOAD_PATH << verdir if Kernel.test(?d,verdir)
# Example: Windows User Documents Common (all versions) Plugins path:
comdir = File.expand_path("~/My Documents/Google Sketchup/Common/Plugins")
$LOAD_PATH << comdir if Kernel.test(?d,comdir)
# Add additional paths here.
$LOAD_PATH.uniq!
if RUBY_PLATFORM =~ /(darwin)/ # Mac OSX
# Example: Mac User Documents Current Version Plugins path:
verdir = File.expand_path("~/Documents/Google_Sketchup/Sketchup_#{Sketchup.version.to_i}/Plugins")
# Example: Mac User Documents Common (all versions) Plugins path:
comdir = File.expand_path("~/Documents/Google_Sketchup/Common/Plugins")
$LOAD_PATH.uniq!
# Load all "!_autoload" folders, that reside in any of the $LOAD_PATH
# array folders.
$LOAD_PATH.each do |abspath|
autodir = "!_autoload"
autopath = File.join(abspath,autodir)
if Kernel.test(?d,autopath)
Dir.new( autopath ).each { |file|
ext = File.extname(file)
next if ext.empty? || ext[-1,1]=="!" # skip if ends in '!'
begin
if ext == ".rbs"
Sketchup.require( "#{autodir}/#{file}" )
elsif [".rb",".rbw",".o",".so",".dll",".dylib",".bundle"].include?(ext)
rescue Exception => e
puts("File: '#{autodir}/#{file}' did not load:")
puts("Error: #<#{e.class.name}: #{e.message}>")
puts e.backtrace unless $VERBOSE.nil?
else
puts("File: '#{autodir}/#{file}' loaded successfully.")
end #if autopath
# Any other require() calls to load scripts in subfolders,
# or in the Ruby lib path subfolders... etc.
# Any additional configuration calls
