by g.moggel » Wed Feb 09, 2011 9:09 pm
hey guys. first up, i dont take credit for that plugin. its by axel lee. i found this plugin rantexpos at http://rhin.crai.archi.fr/rld/plugin_details.php?id=324it doesnt seem to work in su 8. can one of you look into it and maybe correct it? i'm not into coding but really need this to work. its supposed to randomize the texture position of the selected group/faces. code is as follows. - Code: Select all
def rantexpos Sketchup.active_model.start_operation("RANTEXPOS!") selected = Sketchup.active_model.selection for ent in selected if( ent.is_a? Sketchup::Face ) tex = ent.material texpoint = [] texpoint.push [rand(2048), rand(2048), rand(2048)] texpoint.push [rand(2048), rand(2048), rand(2048)] texpoints = [texpoint[0],texpoint[1]] ent.position_material (tex, texpoints, true) ent.position_material (tex, texpoints, false) end if( ent.is_a? Sketchup::Group ) for fac in ent.entities if( fac.is_a? Sketchup::Face ) tex = ent.material texpoint = [] texpoint.push [rand(2048), rand(2048), rand(2048)] texpoint.push [rand(2048), rand(2048), rand(2048)] texpoints = [texpoint[0],texpoint[1]] fac.position_material (tex, texpoints, true) fac.position_material (tex, texpoints, false)
end end end end Sketchup.active_model.commit_operation end
filename="rantexpos.rb"
if !file_loaded?(filename) plugins_menu = UI.menu("Plugins") if plugins_menu plugins_menu.add_separator plugins_menu.add_item("Randomize texture positions") {rantexpos} end file_loaded(filename) end
thanks in advance.
Reason: Added [Code] tag for indexing
g.moggel
- Name: g.moggel
by Dan Rathbun » Thu Feb 10, 2011 8:37 am
g.moggel wrote:it doesnt seem to work in su 8.
Parenthesized argument lists for methods. (And remove a few spaces when they were in between method names and arg lists. This causes an error in Ruby 1.8.6) Wrapped in a module. Added Constants at top for setting menus. - Code: Select all
module AxelLee
TOPMENU = 'Plugins' unless defined?(TOPMENU) SUBMENU = "" unless defined?(SUBMENU)
Filename = File.basename(__FILE__).downcase
module_function def rantexpos Sketchup.active_model.start_operation("RANTEXPOS!") selected = Sketchup.active_model.selection for ent in selected if ent.is_a?(Sketchup::Face) tex = ent.material texpoint = [] texpoint.push([rand(2048), rand(2048), rand(2048)]) texpoint.push([rand(2048), rand(2048), rand(2048)]) texpoints = [texpoint[0],texpoint[1]] ent.position_material(tex, texpoints, true) ent.position_material(tex, texpoints, false) end if ent.is_a?(Sketchup::Group) for fac in ent.entities if fac.is_a?(Sketchup::Face) tex = ent.material texpoint = [] texpoint.push([rand(2048), rand(2048), rand(2048)]) texpoint.push([rand(2048), rand(2048), rand(2048)]) texpoints = [texpoint[0],texpoint[1]] fac.position_material(tex, texpoints, true) fac.position_material(tex, texpoints, false)
if !file_loaded?(Filename)
@@topmenu=UI.menu(TOPMENU) unless SUBMENU.empty? @@menu=@@topmenu.add_submenu(SUBMENU) else @@menu=@@topmenu end @@menu.add_item("Randomize texture positions") {rantexpos}
file_loaded(Filename) end
I'm not here much anymore. But a PM will fire email notifications.
Dan Rathbun
- PluginStore Author
- Name: Dan Rathbun
- Operating system: Windows
- SketchUp version: 2015
- License type: Pro
- SketchUp use: education
- Level of SketchUp: Advanced
by g.moggel » Thu Feb 10, 2011 10:05 am
thanks dan for looking into it. when starting sketchup i get an error now:
"Error Loading File rantexpos.rb undefined local variable or method `filename' for AxelLee:Module"
and still when i start the plugin from the plugins menu su crashes.
greets, mo
g.moggel
- Name: g.moggel
by Didier Bur » Thu Feb 10, 2011 12:50 pm
Typo: replace: file_loaded(filename) with: file_loaded(Filename)
Didier Bur
Didier Bur
- Name: Didier Bur
- SketchUp version: 2020
- License type: Pro
- SketchUp use: architecture
by Dan Rathbun » Thu Feb 10, 2011 4:59 pm
Didier Bur wrote:Typo: replace: file_loaded(filename) with: file_loaded(Filename)
Done. Edited the code. I did that in a secs just before bed. I have not tested it. (I assume it worked under Ruby 1.8.0, and didn't under 1.8.6 because of spaces between method names and argumentlists, etc.)
Dan Rathbun
- Name: Dan Rathbun
- License type: Pro
by Dan Rathbun » Thu Feb 10, 2011 6:47 pm
g.moggel wrote:and still when i start the plugin from the plugins menu su crashes.
I was able to get it to work on a simple model (attached.) SaucePan.skp I was also able to get a BugSplat! on a very complex old ver 7.1 model. I selected the terrian mesh, and tried it on that. (splatto!)
Dan Rathbun
- Name: Dan Rathbun
- License type: Pro
by g.moggel » Sun Feb 13, 2011 9:58 am
hey man this is awesome. i needed to make a cutting board like ikeas whole-wood boards and they consist of individual parts glued together... anyway: NICE ONE! although i have another thing. the textures original rotation is changed and completely oriented in the other way. is it possible to not let the rotation change or choose whether it randomizes rotation at a given angle? thanks again, this was a big help  greets, mo
g.moggel
- Name: g.moggel
by Dan Rathbun » Sun Feb 13, 2011 11:18 pm
I don't have time myself to work on this. Um.. if you have control.. then it would no longer be random ? but I did notice that when I ran it on a pavement texture on a bridge model, that the roadway became misalign with the bridge. (Looked terrible.)
Dan Rathbun
- Name: Dan Rathbun
- License type: Pro
by g.moggel » Mon Feb 14, 2011 12:37 am
figured it out. i just need to rotate my face/object to be oriented with the axis. then i can hit rantexpos and it aligns them in the other way. thanks again for your help.
mo
g.moggel
- Name: g.moggel
- Robot
Return to Developers' Forum
